Gearing on a Quattro
rafA4 Jun 25, 2004
  1. rafA4
    rafA4 Member
    33
    Is there any way to change the gearing on a 1.8t Quattro, because it seems as when I am just getting the right boost level it's time swicth gear feels like mine are too short. OH and Has anyone been able to swap out gear boxs from S4 to A4 so that the A4 has 6 speed trans. /ubbthreads/images/graemlins/grin.gif
  2. ImolaS4
    ImolaS4 Member
    275
    never heard of swapping trannys.
    At what rpms are you seeing boost levels and the need to shift?
  3. rafA4
    rafA4 Member
    33
    Just seems that my gear are two short.
  4. ImolaS4
    ImolaS4 Member
    275
    Mmmmmkay... you didn't answer my question so I don't know how else to help you.
    I asked because I wanted to see if the boost and rpms match well.
  5. rafA4
    rafA4 Member
    33
    Sorry about not responding, I notice strong boost around 3 to 4k rpm and then drop off.
  6. GregC
    GregC Member
    278
    I know exactly what you mean my car has 240ish BHP (up from 180) - once you get a little more power first gear becomes a waste of time, you go through it so fast that you simply have to change up as soon as the Turbo has kicked in. Second also stops at 55 (60 at a push) so you have to use third for fast overtaking on non-dual carriage ways. Finally fifth is to low for relaxed cruising.
    I looked into the possibility of changing the final drive ratio as this would move everything up a notch but couldn't find anyone who could answer questions about feasability.
    I spoke to Kim Collins at QS Tuning re getting a S4 box on the A4 - he said it would fit but would cost £3,000 + as all the running gear would likely need to change.
    If anyone can answer this problem for a reasonable cost I would definately be interested.
