Gearboxes
ScottD3
Supporter
Plymouth
Website
wheelsnwires.blogspot.com
While stuck at home bored my mind started to wander to thoughts of my auto gearbox and fear that it won't last the year.
It might last but I'm a paranoid soul.
And before aragorn or anyone else starts, I will not convert to manual, so don't go down that route. Thanks :thumbsup:
I was thinking that when my gearbox does eventually go I'd like the 5 speed trip tronic version.
My understanding is that these was fitted to 2.5 TDIs and a high chance they was quattros?
Did they fix this box to 1.9TDI quattros as well?
Is it possible to convert a quattro auto box to FWD?
Would a box from a different 1.9TDI or a V6 fit my AFN TDI?
I guess the bell housings would be different, so could they be swapped over?
Most audi engines use a common bellhousing. The ratios are usually specific to the engine though.
Converting a quattro box is pointless and probably not even possible, stick to FWD boxes.
I think the later cars got the tiptronic box so why not just get a later 1.9tdi facelift box?
For now it's about options. When I need a box or will be about availability at the time.
If a FL trip 1.9TDI box appears, bonus. If not then it's when I can get at the time.
Say, a Quattro version of the above.
I don't know what a Quattro box looks like or what is different between the two. I'm curious if it's possible.
the whole rear housing is different, conversion might be possible, but you'd need a FWD rear housing, and those generally come attached to a FWD gearbox ;)
Like the one on my car?
That's assuming they are interchangeable............I'll stick with FWD boxes if other auto boxes will fit my engine
I doubt they'll be compatible, given its a totally different gearbox, but i cant be sure.
I'd stick with a 1.9tdi box, other boxes will mechanically fit the car, but the gearing wont be correct.
I know of a b5 passat 1,9Tdi PD115 Bhp which is broken for spare, everything is available...tiptronic, FWD gearbox, oil/strainer changed last year, very good running order...
Thanks for info Adam but I'm in a position to buy one yet.
I'm going to wait till my box dies. Information gather at the moment.
632
741
755
609
