Gearbox Service (Norfolk)
ollie2013uk
Active Member
Norwich
Can anyone recommend a good place to have the ATF fluid changed and a gasket replaced in Norfolk or outside Norfolk for my S4? I frequent Manchester regularly.
Also if anyone has had theirs done can they advise a ball park price?
Had done at MCC near Bury St Edmunds, they did a good job.
Thanks, how much did you pay out of interest? I heard the oil is around £30 a ltr and it takes 9?
I bought the oil myself from Audi (can't remember how much exactly) and then labour there is 40/hour. At the same time I had brake fluid and power steering fluid changed and it came to 120.
Thanks mate, I called Audi, OH MY GOD they are so so so useless!! They said it was no serviceable and also that it has lifetime oil but no life time warranty!! It's in tomorrow morning with Yelverton garage an Audi/VW specialist. So i'll see what they say about it.
Called Das Autohouse in Norwich, they wanted £45+Vat to diagnose a problem I told them it had! Then when I would of had the work done there they wouldn't have reduced my final bill by £45+vat! So they just lost a good customer!
Awesome GTI in Manchester didn't want to know either which I found a bit weird!
http://jrd-norwich.co.uk
Had these guys repair my manual gearbox.
Had Oil change, clutch, flywheel and changed couple of pinion gears. They also did rear diff oil. Great service and was reasonably priced if I remember correctly.
Supplied my own oil, clutch and flywheel (got parts from tps via dub generation owners club)
Hope you have more luck with yelverton than I did. Went in to see them about changing into my chain tensioners. Said they were gonna price up but never called me back.
always use yelverton-have done for years, never had a problem with any work they have done
Reactions: ollie2013uk
Right, took the car to the Audi Specialist, can't recommend them enough, looked at my leak, looks like its the seals from the engine to the box maybe the torque converter.
808
883
10
916
