Gearbox rattle
Rigla Sep 2, 2010
  1. Rigla
    Rigla S Line
    Hi guys,
    I've noticed my car has a rattle on a cold start and when its had a good run im 90% sure its the gearbox its like a mechanical rattle
    Any ideas...clutch and gear change feel ok
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Might be the flywheel
  3. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,264
    363
    i agree with the last post sounds like your dual mass flywheel is shot had a similar noise on a car in work and it turned out it was the d.m.f and it wasnt cheap but i would get it checked out by a garage
  4. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Yep sounds like the DMF is on the way out.
  5. 964kevin
    964kevin Member
    110
    Describe the noise when hot, and if it goes quiet when you dip the clutch and engage a gear.
    K
  6. Rigla
    Rigla S Line
    Its hard to describle it like something is rattling when its cold but when its warm(not always) it rattles but no as much it kinda blends into the diesel tick over but its noticable
  7. 964kevin
    964kevin Member
    110
    Does it change if you engage the clutch and first gear?
    k
  8. Rigla
    Rigla S Line
    I dont know i think the noise goes then...but i can tbe sure
  9. 964kevin
    964kevin Member
    110
    Ok, you'll know for sure if this is the case, the only reason I comment is because mine had a new box when it made this noise, and it was noisey.
    k
  10. Rigla
    Rigla S Line
    So if the noise goes when in gear and engage a biting point its the flywheel?
  11. Rigla
    Rigla S Line
    Right, cold start this afternoon, rattle as usual, dipped clutch still rattles, clutch down 1 engaged still rattles, find biting point in first...No rattle...
    Any ideas?
  12. 964kevin
    964kevin Member
    110
    Ok, not the gearbox symptoms I had then, so thats out of the way. Possible the DMF I would suggest.
    k
