gearbox oil (will this be ok?)
matty907 Sep 8, 2010
  1. matty907
    matty907 New Member
  2. b1gdave83
    b1gdave83 Member
    159
    Sorry I can't answer your question, but I always go to 'TPS' and get the original Audi gearbox oil. It's not expensive.
  3. Matt82
    Matt82 Active Member
    2,365
    same here. easier life. just get what vag put in there because VAG are not particularly open about the spec of fluid that goes in there
  4. matty907
    matty907 New Member
    ok cool, thanks, its just what opie recommend,
    oh and my local audi dealer is 40 miles away, could i get it from a vw garage?????
  5. Matt82
    2,365
    yes. theyre the same car!
  6. matty907
    matty907 New Member
    great the vw garage is 5 mins down the road so that will save me a bit of time and money lol.
    cheers guys
  7. S3 TAM
    S3 TAM Pocket now empty
    624
    10
  8. Matt82
    2,365
    fantastic... when you gonna be racing it?
  9. S3 TAM
    624
    10
    Every time I drive it. Lol
    Na next year when we go to the ring.
  10. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Is it a hard procedure to replace the gearbox oil? How much on average would a specialist charge? (thinking of doing this next service if it's not a massive job)
  11. b1gdave83
    b1gdave83 Member
    159
    Very easy,
    Jack car up (level)
    Remove filler/level plug first (just encase you can't get it undone before you drain the oil)
    Undo drain plug, and drain oil. Put plug back in or run some new oil through first, then re-fit plug.
    Two ways to refill use a pump or pump bottle from low level, or do what I did. Use a hose and funnel above the engine bay and route the hose into the filler plug and re-fill.
    If you have a 6 speed box buy 3 litres you may not need it all.
    You know when it is full because it comes out the filler/level plug. Do filler plug back up.
  12. matty907
    matty907 New Member
    bought all my oils and away to change both engine and gearbox oil today, new strut top mounts, new denso spark plugs, new fuel filter..... just wish my lowering springs had arrived yesterday....!!!
    busy busy day, just hope it doesnt rain AGAIN!!!!!!! lol
    F*ckin scotland for you... lol
  13. jackera
    jackera New Member
    Hi, i think i may have been lied to my local mechanic, just booked my 1999 18.T in for an oil, filter and strainer change asked about the gearbox oil an he said its a sealed unit cant be changed. Its done 94K
  14. Pabl0
    Pabl0 Member
    140
    It can be done very easily, would take a mechanic minutes to do. Although it would be alot easier for you to do, the mechanic doesn't fill me with hope.
  15. b1gdave83
    b1gdave83 Member
    159
    If you saw the **** that comes out, you would defiantly want the oil changed, I don't care what people say it does need changing. Oil still degrades....
