Gearbox change
cerips Jan 1, 2011
  1. cerips
    cerips Member
    54
    I've managed to source a second hand box for my 2.5tdi, apart from a new clutch what other jobs are worth doing while I'm taking the box out?
    It's a facelifted 2wd by the way.
    Cheers in advance.
  2. Broken Byzan
    13,237
    466
    Change the oil in the box too, thats about it tbh.
  3. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Check the needle bearing in the end of the flywheel and replace if necessary and also check the flywheel for play...
  4. cerips
    cerips Member
    54
    I take it the needle bearing doesn't come in a clutch kit?
    Any advice on where to get one? The car has done over 190K now so I might as well change it while the box is off.
  5. adamss24
    4,584
    407
    Try the dealer...or ECP but when there is soo much labour involved i would allways go for the genuine part !
