Gearbox and Rear diff oil
rolo tomassi Jun 24, 2009
  1. rolo tomassi
    rolo tomassi New Member
    17
    Just wondering if anybody knows how often these oils have to be changed. The cars just done 60,000 miles and not sure if any of them have been changed before.
  2. Broken Byzan
    13,235
    464
    They are supposed to be sealed for life, but they are both changeable. 75/90 is recomended for both around 4 littres iirc. So probably cheaper to buy a 5 litre container. However i would change it to full synth and add some shockproof oil into the mix. It can help a lot with fast changes and hard launches etc
  3. rolo tomassi
    17
    Cheers hey. Is there specialised tools needed if i did decide to change it?
  4. barters3
    barters3 Member
    438
    I want to change my gearbox oil,hopefuly to take a bit of clunk out of gear changes. What brand of oil would you recomend?
  5. S3Steve
    S3Steve Active Member VCDS Map User
    1,608
    17
    You need a VAG gearbox sumpplug tool to change the gearbox oil. IVe recently switched to Motul Gear 300 and its made a big difference to the gear change feels so much better and no crunch from second to third since the change.
  6. barters3
    barters3 Member
    438
    how many litres will i need for just the gearbox change?
  7. S3Steve
    1,608
    17
    2.6 litres to do the gearbox and transfer box which is attached to the gearbox iirc, so you'll need to buy 3 1 litre bottles.
  8. Dani_B19
    8,977
    321
    Transfer box, is that for the rear diff?
  9. Broken Byzan
    13,235
    464
    The Xfer box is directly connected to the gearbox and is lubricated by the same oil. The rear diff is at the rear of the car and although connected to the Haldex, is lubed seperatley
  10. Dani_B19
    8,977
    321
    Ok i get you, so both have tobe changed seperately, how hard is it todo the rear diff?
