Gear knob...
[Dave B] Feb 26, 2003
  1. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Anyone know how to get the existing one off as mines **** and i'd like change it. Mine looks like its a carbon fibre one (or lookalike anyway), is this standard?
  2. DMitch
    DMitch New Member
    Not sure about how to get the knob off, but I can tell you that mine is leather, but that probably comes with the .5 leather pack mine has.
  3. ooooaudi
    ooooaudi Member
    168
    Give it a pull /ubbthreads/images/graemlins/tongue.gif
  4. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I'd just try and pull my knob off but am scared it will do some damage /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/laugh_roll.gif /ubbthreads/images/graemlins/laugh_2.gif /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/laugh_roll.gif
  5. rockstar
    rockstar Member
    124
    why not just get "someone" to give the old knob some spit and shine...........am sure it will come "up" a treat! /ubbthreads/images/graemlins/laugh_2.gif /ubbthreads/images/graemlins/laugh_roll.gif /ubbthreads/images/graemlins/angel.gif
  6. Mo-S3
    Mo-S3 Member
    706
    U CANT pull it off !! As u may know if u pull any knob' too hard u'll damage it !! and that could be very painful !! I mean financially ok !!
    The gear knob is held on with the special circlip under the leather gaiter. U need to remove the trim around the base of the gaiter and then pull the leather upwards over the knob and u will see the clip holding it in place. To remove the clip use a small screwdriver very carefully and prise the clip 'wide' and it should slip off. If ur not careful u could end up slipping off the clip and into and through the leather!! If u do then ur fecked !! To replace the gear knob u will have to purchase a new clip to fit the knob back on other wise it will keep coming off. And NO u cant use a jubilee clip coz its too FAT and will poke through the leather. I hope this is clear enough for you.
  7. CARACTERE007
    CARACTERE007 Member
    319
    i did this with mine... broke it...but fixed it....and all the gear knobs i bought (2) did not fit as it did not have anything to grasp once the knob is taken off...err on 97 model by the way....might be different for other newer versions..
  8. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I was considering fitting a Momo gear knob, but if the fitment is a bit specific I suppose it might just be best to buy an Audi one? If they're available?
  9. ooooaudi
    ooooaudi Member
    168
    give awesome a bel, jim should know what nobs will fit !!
  10. SimonPoole
    SimonPoole Member
    30
    The Momo knobs have three grub screws which allow them to be fixed to the gear lever. The problem then is that you are left with a gaping hole in the top of the gaiter.
    I had a friendly tool maker turn up a new ferrule for me and attached the gaiter to this just below the gear knob.
  11. dans3
    dans3 Member
    76
  12. Khufu
    Khufu Well-Known Member
    5,704
    31
    get a skull, they are nice and tasteful /ubbthreads/images/graemlins/vomit.gif As for removing them, I almost pulled mine off on the Scottish meet desperately trying to get to 3rd /ubbthreads/images/graemlins/blush.gif so I can't have a circlip on mine. (pre-facelift)
  13. darkspin
    darkspin Member
    45
    ive done a search on gear knobs and came up with this old thread.
    Did any of you find the momo gear knob cheaper than this place and if so let me know your recommendations? (go right to the bottom of the page) http://www.speeding.co.uk/acatalog/Products_Gear_Knobs_144.html
    I want to get the black leather one but do any of you also know whether it shows the gears on the top of the knob or is it just a design if you know what i mean
  14. CARACTERE007
    CARACTERE007 Member
    319
    dont buy the richbrook stuff...they are ****,..bad fitting etc
  15. Markb
    Markb Active Member
    2,139
    Buy Momo quality gear /ubbthreads/images/graemlins/wink.gif
    Haven't given the Gear Knob any thought to be honest.
    What have the latter models/S3's got on them?
  16. can7ona
    can7ona New Member
    The gear knob is easy to get off without ripping it off... the best way I found was to take off the top part (that shows the gears) and then unscrew the whole thing (from my experience this didn't mess anything up) and lift it all up... The gaiter is clipped onto the knob but I just ripped that part off without any problems...
    I did find though that when I had the new knob on (a Momo Cobra) Id obviously lost the push-down reverse and ended up getting into reverse gear when trying to get into first! (not fun... trust me!)
    As far as I know the only knob that will work is the Momo one for VAG cars (not seen this so don't know how it works)... If all else fails the old gear knob and stick clip back in ok (once its been screwed in)...
  17. garethj
    garethj Member
    396
    Just replaced mine on a new A3, it is held in place by a small metal clip which is squashed with a pliers until it holds the knob tightly on the shaft (pphhnarrr!).
    If you do have a carbon look knob on your car it is probably worth flogging it on e-bay after you take it off, the Audi part sells for approx £100.
    Taken from www.speeding.co.uk
    Sphere Gear Knob SPECIAL FIT VW/Audi/Seat/Skoda
    These gorgeous MOMO gear knobs are special fit design for the Following Vehicles:-
    Audi A3-A4 Seat Arosa, Cordoba, Ibiza & Toledo. Skoda Fabia & Octavia. VW New Beetle, Bora, Golf 4, Passat, Lupo & Polo.
    Choose from Aluminium with Black Leather or the Solid Aluminium design. Supplied complete with full fitting instructions and all parts. Due to the unique gear shafts of the above vehicles, these are the only gear knobs that fit correctly !
  18. A3LX
    A3LX New Member
    Do you know where I can get the circlip from?
  19. Agric04
    Agric04 Member VCDS Map User
    288
    I changed my worn original S3 gear knob and gaiter last month. Bought a new genuine Audi S3 one from my local dealership for £32 (part number 8L0 863 278 BJ 6BN) which is the complete gear knob and gaiter.
    Very easy to change, the leather section just unclips and pulls over the gear knob exposing the metal crimped clip which was a bit of a pain to break off. The new gear knob and gaiter then just slides over the gear stick and clips in place, I didn't bother crimping the new metal clip as I didn't have a suitable tool to do it, but as it turns out I don't need to as the new gear knob sits perfectly nice and tight without it.
    Here's some pics of my old gear knob which I hope might help:
  20. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Or you can replace with a 8P S3 nob which fits perfectly with the stiched gaitor like I have.. Mine is identical to this pic, matches my cream recaros perfectly.... Not cheap though at abot £70 all in I believe... But look lovely and OEM, plus a tad shorter to.
  21. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    155
  22. Steveo_A3_1.8t
    Steveo_A3_1.8t Member
    197
    Ha ha ha ha ha ha ha ha ha nobody likes a damaged knob!!
  23. fingermouse
    fingermouse thats me
    3,974
    110
    WOW thats my car in the top PIC :)
