Gear change "Burp" on tfsi w/ S-tronic/DSG
A3SBQ Apr 13, 2013
  1. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    475
    74
    Hi all.
    I am some how fascinated by the gear change burp
    coming from tfsi cars with the DSG box.
    Whats making this and can/will this be enhanced after a remap?
    Will a new exhaust do anything with this?
    Have seen the new S3 and A-class AMG on YouTube and its just pure audio porn.
    I am planing to opgrade the turbo to a K04 and the kit is without turbo nous suppressor!
    Anyone know something about this?
    Thanks for any feedback.
  2. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Milltek TBE resonated slightly enhanced the gear change `parp` on my S3 DSG.
    cheers
  3. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
  4. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    DSG cuts the ignition momentarily during a gear change. It is very very slight. The DSG/Stronic is arguably the best box in the world, and changes gear in less than 7ms. The only way the engine power can be cut for such a short duration is with an ignition cut/retard.
    If you leave it a touch longer, this is what you get:
    https://www.youtube.com/watch?feature=player_embedded&v=8IddRNFb22o
  5. Ads
    Ads License to drive
    8,230
    610
    What do the cops do if they see that?
  6. mjr901
    mjr901 Guest
    Think that's something i definitely want, but not as often as that. just occasionally.
  7. A3SBQ
    475
    74
    Hi all.
    Thanks for replying.
    I do like the flames. But I think for a trackday map and not for streets as the cops will hunt you down.
    @Rick: how is you sw at normal driving. Does is stil shooting flames?
    If I understand you correctly. The burp is from engine ignition cutoff/retard. Is this basically a stock flat shift system on the DSG cars?
    You say it can be extended in time, dose the longer cutoff decreas the performance or is it nOt notable?
    Thanks for the info
  8. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    if you think those flames are bad try driving something with launch control, anti lag, flat shift, traction control (all doing igntion cut) and plenty of fuel on overrun lol
  9. JS3
    JS3 Member VCDS Map User
    227
    Paul - any chance you have a video of the parp with the Milltek? Also when the Milltek is installed, where does the small butterfly valve go that is at the rear of the OEM exhaust? Thanks.
  10. Rick @ Unicorn Motor Dev.
    1,271
    611
    I'm working on a flatshift implementation for DSG, but it's on hold due to other projects. In reality, you're not going to improve on the standard system for daily use. I will probably end up doing a switchable map that is more aggressive than standard. As standard the boost request is dropped during gear change but it's only slight.
    Rick
  11. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    I found Milltek TBE resonated to have less burb then stock exhaust as it removes the back box flap that enhances gearshifts burb.
  12. Cmw9
    Cmw9 Member
    252
    21
    I recently added an evoms induction kit to my a3 quattro s tronic and now it farts when changing gear. It is fairly subtle at the moment but i have just ordered a milltek cat back to go on in a couple of weeks, hopefully it will get even better
