gear box question
toaophil Jun 4, 2013
  1. toaophil
    toaophil Audi!
    69
    Would a gear box oil change stop the gear selection being so 'clicky'? Especially first and second gear, they're not over easy to select, and if your windows are down for example- its quite noisy as you put it in gear.
    Any knowledge appreciated!
  2. Mike B
    Mike B Well-Known Member
    1,114
    40
    Might be the clutch otherwise Molyslip could help or its just wear
  3. toaophil
    toaophil Audi!
    69
    Molyslip. . . as in do a gearbox oil change to molyslip?
  4. Mike B
    1,114
    40
    Just add it to the new oil.Helped with my wifes Bora which was notchy in 4th and 5th but if its 1st and 2nd its more likely the synchro is dodgy or the clutch is failing
  5. Andie0
    Andie0 Member
    490
    13
    Mine is also clciky is first and second always has been and selects fine with no resistance! Just seems to make that noise, changed the fluid and no change!
  6. Audi Doodah
    Audi Doodah Active Member
    377
    35
    I did an oil change and it improved the notchiness I had. Had a new clutch fitted not long after and saw furthur improvement. Can still hear my linkage with windows down though...it is mechanical movement, after all.
  7. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    could be gear linkage bushings that have worn. creating a poorly selected gear.
  8. deano1978
    deano1978 different gear
    713
    81
    how did you find out which oil and how much? Mines 04 sport like urs.
  9. Audi Doodah
    377
    35
    75W-90 Fully Synthetic, so says the Audi bible. Give me your gearbox code off your service sticker and I'll check the capacity.
  10. deano1978
    713
    81
    where is mine? Am i looking for special sticker with info on it?.
    Dont seem to have one! Not in boot,engine bay or door arch??
  11. bradh
    bradh Active Member VCDS Map User
    573
    58
    Try under the rear bench seat that's ware I found mine
  12. Audi Doodah
    377
    35
    It is on the first page of the service booklet too but I suppose you can't find that either!? :laugh:
    All the 6 speed boxes have a 3 litre capacity and I used Castrol in mine (see the link) but the Audi part number is G 052 911 A
    A mini how to in this thread
    deano1978 likes this.
  13. boost-addict
    1,000
    39
    If you pm me your reg ill look it up at work.
  14. deano1978
    713
    81
    appreciated...R15 DDH
  15. boost-addict
    1,000
    39
    lol im not at work any more, let me see if i can access a website we can turn to at work if our system dosnt show any info
  16. boost-addict
    1,000
    39
    need your vechile details, its not telling me decent enough info
    need model, spec, enigne size (more importantly what bhp one if theres variants) and year
  17. boost-addict
    1,000
    39
    dw done it
    Code:
    [TABLE="width: 550"]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]        Engine	 (DT)[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]       EDGE 5W-30 (a)[/B][/FONT][/TD]
    [TD="width: 140, bgcolor: #ECECED"][FONT=Arial][B]   4.0L[/B][/FONT][/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: recommendText, width: 14, bgcolor: #ECECED"][/TD]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Manual Transmission[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]Syntrax Long Life 75W-90[/B][/FONT][/TD]
    [TD="width: 140, bgcolor: #ECECED"][FONT=Arial][B]2.3L[/B][/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Automatic Transmission[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]Refer to main dealer[/B][/FONT][/TD]
    [TD="width: 140, bgcolor: #ECECED"][FONT=Arial][B]4.5 - 5.0L[/B][/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Differential[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]From Gearbox[/B][/FONT][/TD]
    [TD="width: 140, bgcolor: #ECECED"][/TD]
    [/TR]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Coolant[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]G13[/B][/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Brake Fluid[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]React Performance DOT 4[/B][/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Multitronic transmission, differential[/B][/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 181, bgcolor: #ECECED"][FONT=Arial][B]Wheel Bearings[/B][/FONT][/TD]
    [TD="width: 215, bgcolor: #ECECED"][FONT=Arial][B]Multipurpose Grease[/B][/FONT][/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
  18. deano1978
    713
    81
    Thanks boost-addict :)
    boost-addict likes this.
  19. boost-addict
    1,000
    39
    Thats what your after
  20. boost-addict
    1,000
    39
  21. Audi Doodah
    377
    35
    Exactly what I used and linked to in my mini guide :laugh: £12.99 a litre or £10 with a trade card.
  22. boost-addict
    1,000
    39
    I missed the link. That or the advanced multigear one. Same stuff, different bottle
  23. deano1978
    713
    81
    Thanks very much for your help.
  24. Gully
    Gully Newbie
    9
    I got the same thing going on too! 2004 1.8 t 190 , 2nd is a bit of a crunch but when warmed up is fine ,new clutch about 5k ago. Is it a common thing with the a4s ?
    :huh:
