Gear box problems A4 Avant, gearbox code DHL.
slats0356 Feb 11, 2012
  1. slats0356
    slats0356 New Member
    Hi,
    my 97 tdi avant has started buzzing slightly in 3rd gear when changing up and down, and every now and then its difficult and sometimes impossible to shift from 1st to 2nd. Im guessing that i need to replace the gearbox but im finding it difficult to find a dhl box, are there any other tdi boxes that are compatible with the AHU engine. Any advice welcome.
    thanks. Al
  2. Alsie
    Alsie Member
    133
    I'm breaking a 98 Tdi avant :)
  3. Nessy
    Nessy VW + Audi mad
    973
    97
    If you do end up replacing the gearbox, don't forget that many mechanical parts of the A4 are shared with the Passat, and so can be had for less than bumped-up Audi prices!
    My car now has a 'box sourced from a TDi Passat, identical in every way (same part number etc etc) but was way cheaper than sourcing an 'Audi' one.................
  4. slats0356
    Thanks for that alsie is it a dhl box or will it fit mine?, if your not to far from me i could collect im in sunny cornwall.
  5. slats0356
    Thanks for the info nessy will bear that in mind if i get no joy locally.
  6. Alsie
    Alsie Member
    133
    How do I tell if it's a dhi box, bit on a novice, I'm in south Wales, but was planning on scrapping the car with the engine and box still in it, so the box would be free if you take it out
  7. Nessy
    Nessy VW + Audi mad
    973
    97
    There should be the factory production sticker in the boot area, it lists option codes the car was fitted with, along with engine and gearbox codes IIRC........
  8. Alsie
    Alsie Member
    133
    Will check when I get home
  9. Alsie
    Alsie Member
    133
    cant find said sticker in boot, door shuts or anywhere, any clues anyone?
  10. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,762
    167
    Did you look in the tyre well? Think thats where it is in the boot area.
    In the front page of the service manual? (if you have it!)
  11. Alsie
    Alsie Member
    133
    errr.. no fraid I dont...any other way of telling the spec?
  12. S4_dan
    2,762
    167
    just edited my post.
  13. Alsie
    Alsie Member
    133
    oh ok..BRB
  14. Alsie
    Alsie Member
    133
  15. S4_dan
    2,762
    167
    DHF box in your car then.
    Might be worth seeing what the difference is between a DHF/DHL gearbox. Maybe someone with ETKA could shed some light on this.
  16. S4_dan
    2,762
    167
  17. Alsie
    Alsie Member
    133
    Worth a trip then for a free gearbox :)
  18. slats0356
    Thanks for the offer alsie but i have sourced one locally.
