gear box oil - does it need changing?
barters3 Apr 1, 2009
  1. barters3
    barters3 Member
    438
    my s3 has done 97000, a service is due at 100000 so im going to give it a very thorough service, do i need to get my gear box oil changed, if so is it a major job?
    Also what else should i consider when servicing an s3 of this mileage other than the norm.
    Haldex oil/filter and cam belt have been done.
  2. cjhill
    cjhill hmmmmm interesting.
    335
    ive asked this question before and looked around quite a bit...
    answer - nothing major needs to be done. Just do all the things that the normal service includes. The only extra things i do are to change the oil and filter inbetween the long life service (i.e. every 10,000 instead of 20,000).
    i dont know when your clutch will go but the oil will be changed with that so wait till then ?
    Im sure someone will correct me if they have any better ideas.
    Chris.
    106,000 miles and counting - no problems yet !
  3. A3Gloss
    A3Gloss New Member
    I wouldnt bother changing the gearbox oil m8 just make sure theres enough in it (using the level bung) and it should be ok.
    Just plugs; oil, air and pollen filters. and a good shake aroung the wheels (make sure nothing is hanging off - anti-roll bar links, etc)
    cambelt is the major service ball ache, and thats been done! although putting a new water pump on, whilst the cam belt was off would of been ideal!
  4. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    its not neccasary to change the gear oil but its also not a bad idea either, could help with smothing out gear changes and make the drive feel beeter.
  5. barters3
    barters3 Member
    438
    I changed the water pump when i had my cambelt done,so that should be fine. Gear changes can be a tad clunky sometimes,although nothing out of the ordinary. I think il just check the level then. How do i check the level?wil it be in the manual?
  6. finesse
    finesse Active Member
    2,805
    What gear oil to use please?
  7. Westy
    Westy Well-Known Member
    17,443
    1,104
    I had my rear diff and gearbox oil changed at 110,000 miles and it did make a very slight difference to the gear changes. Apparently Audi say its not needed but I wanted all fluids changed when I bought the car.
  8. Matt82
    Matt82 Active Member
    2,365
    why wouldnt you? it costs buttons
  9. jonny87
    jonny87 Active Member
    1,094
    changed my gear oil at the weekend, used redline lightweight shockproof oil from opie oils would reccommend anyone to do it, i was having issues with slight crunching in 2nd and 4th when cold, this has been drastically reduced if not gone away all together, also when warm feels alot less notchy, generally gives a much nicer feel to my gear changes
    oil cost £13 a litre and i bought/used 3 litres
    old oil looked pretty yucky, if its never been done before then it had done almost 100k, i also changed my rear diff oil, fuchs oil again from opie oils, old oil didnt look too bad but now i know when it has been done for sure, happy days
  10. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    i'd have to agree with johnny. i would reccomend changing the oil. I had mine done about a year ago and it definately improved gear changes for me.
  11. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Is changing the rear diff oil straightforward? Was thinking about doing the same thing.
    What about the haldex oil & filter?
  12. jonny87
    1,094
    rear diff is easy peasy mate, you just need an oil syringe thingy, like a silicone gun but for oil, due to poor access to the fill plug
    best doing it on a ramp mate makes things way easier, had my haldex and filter done at audi, if doing it yourself you will need the special tool to extract the filter (£30 ebay) and then the oil and filter comes in a little kit (ebay again £20-30) audi charged me £90 to do it so thought id rather not have the hassle for the sake of saving £30
  13. The Doctor
    1,394
    189
    I'm clear how to replace the Haldex oil & filter, but where are the drain points/level inspection points for the gearbox & rear diff?
  14. 1animal1
    9,978
    yeah theres nothing worse than using other peoples fluids....especially if the last owner was quite manly :)
  15. mark_sarah
    mark_sarah Limp mode!
    203
    Very interesting.! I noticed my 1999 A3 1.8T sports gears are really tight and clunky when it's cold, but fine when it warms up. What is the recommended weight gear box oil to use? As my local motor factors, have not got it listed!
