Gauge that does everything, but i dont know what it is.
BriggsJ Nov 17, 2012
  1. BriggsJ
    BriggsJ Third Gear
    22
    Hi everyone
    was just parked up in my car and 2 very nice S3's turned up that ive never seen before. I went over for a chat and after talking about the cars one lad had a small electronic gauge fitted in his air vent. I asked him what it was because it was just a blank screen. He turned his car on and showed me.
    He could select loads of different views showing boost pressure, BHP, fault codes that may pop up on the car, all sorts. He told me who made them but in the excitement of seeing something new, ive compleetly forgoten what he said. I think me mentioned racetech, and he said it cost over £200 from what i remember.
    I was wondering if anyone on here might know what it was and where i could find one?
    it was obviously sat inside the air vent, was all digital and the screen was a bit smaller than half an i-phone screen. To look through the menus there was a small black bit that acted like a d-pad.
    Anyone have any ideas. Cheers
  2. Broken Byzan
    13,237
    465
  3. mjr901
    mjr901 Guest
    one of these mate?
    Not mine - i dont have one
  4. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
  5. chris1988brown
    chris1988brown Member
    575
    where can you get these from ?
  6. Brodster
    3,548
    886
    You can get them on Ebay mate.
  7. mjr901
    mjr901 Guest
  8. BriggsJ
    BriggsJ Third Gear
    22
    I mannaged to find them on the internet, and your right they are Liquid Guages. They are pretty expensive though, but when i saw one in action they do enough to justify the money i think.
    cheers everyone.
  9. JPK
    JPK Active Member
    303
  10. MrLapou
    MrLapou Well-Known Member
    1,233
    121
  11. Marshallman
    Marshallman New Member
    13
    THat looks a quality bit of kit and very in keeping with OEM :)
  12. Dan-1981
    Dan-1981 Active Member Team V6 quattro Audi A4 Audi Avant Owner Group Black Edition TDi
    312
    64
  13. Trevor Locke
    Trevor Locke Stockton on Tees
    89
    Scangauge on mine, it is now on the sun flap above the rear view mirror though.
  14. Dan-1981
    312
    64
    Easy to install?
    Sent from my HTC One_M8 using Tapatalk
  15. CheeseGrater89
    CheeseGrater89 New Member
    13
    Just throwing in my 2 pennies.
    Google: Torque android supermini OBDII bluetooth adaptor
    One of my work colleagues has this in his Leon FR.. its pretty cheap (and a bit naff imo) but it seems to work ok . It runs live data to an app on your phone. Good for quick diagnostics I suppose.
    Personally, I dont think you can beat a good mechanical gauge!:playful:
  16. kash_v
    kash_v Active Member
    360
    76
    I have the torque app, for some reason doesnt show boost on my S3.
  17. Dan-1981
    312
    64
    I also have the Torque app, I had to select the Boot gauge from a sub menu, i'll try and get a snapshot.
    S. likes this.
  18. Trevor Locke
    89
    I used to use Dash command on the head unit (until i broke the connecter on the head unit when pulling it out) that worked really well
    I can still use it but just on my phone
  19. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    625
    107
    43
    Was that on Android - Apple don't want to approve them for use on CarPlay :(
  20. Trevor Locke
    89
    No, on my Iphone
  21. Trevor Locke
    89
    broke this connector off, so can't use it on the head unit now :-(
  22. downtothebone
    625
    107
    43
    Ok - can you give a heads up of how your setup did work? I can connect my iPhone to my head unit via USB but then the unit just goes into CarPlay which won't show Dash Command. I can of course just have Dash Command show on my iphone but that's not very elegant. Thx.
  23. tcardio
    tcardio Well-Known Member
    992
    287
    +1 for P3cars. look oem and air still goes through vent. Just a note...do not use the vw/audi obd splitter on eBay. It does not communicate with all the modules. order the gauge with the white output and red bar
  24. Trevor Locke
    89
    You need the cable that plugs into the yellow connector at the back of the unit and it also plugs into the USB port. The cables are about
    £10 on ebay. Then you change the setting to iphone in the menu.
