Gas gauge problem
Nimosonen Aug 17, 2013
  1. Nimosonen
    Nimosonen Member
    129
    Hey guys. My gas gauge is showing me wrong all the time. When I fill my tank up, it indicates 5/4 gas. And it stays there for like 200km. When I have 1/4 tank left, the fuel warning lights comes up. What can be wrong?
  2. <tuffty/>
    21,145
    3,833
    Fuel tank sender I suspect.. any fault codes?
  3. Nimosonen
    Nimosonen Member
    129
    I don't have acces on VAGCOM, so I don't have any codes. Is it possible to change the fuel tank sender?
  4. <tuffty/>
    21,145
    3,833
  5. Nimosonen
    Nimosonen Member
    129
    Thank you mate :)
  6. Nimosonen
    Nimosonen Member
    129
    I've done some research, and it seems like the sender and the pump are 1 unit.. The pump costs 300$..
  7. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    does the speedo work?
  8. Nimosonen
    Nimosonen Member
    129
    Yes, everything else but the fuel gauge is working
  9. phil miller
    1,211
    166
    check the fuses and if all is good, check the gauge when manually moving the level float, if still not working then it needs replacing :)
  10. Nimosonen
    Nimosonen Member
    129
    How can I manually move the level float?
  11. Nimosonen
    Nimosonen Member
    129
    I've uptained that I get low fuel warning light when I'm almost empty. The gauge is showing 1/4 of a tank still. Is there a good reason for that? Seems like the sensor is working fine, but its just showing wrong in the dash..
