garrett turbo
jim s3 Aug 21, 2008
  1. jim s3
    jim s3 Member
    321
    does any one know the size of the oil and water lines for a garrett turbo i think they are 11mm but need it confirmed as getting the pipes made up the week end thanks...
  2. HTC
    HTC Active Member
    3,428
    9
    This should help you.
    Nice turbo. Your going to make some good power with that spec. Pretty good spool and you're still in high efficiency zone all the way up to 25+ psi at high revs.
    Post up a dyno when you have one.
  3. jim s3
    jim s3 Member
    321
    cheers mate i knew you would reply lol.... its nearly done just need to get clutch and put injectors in and get regulator but not sure witch one any ideas?
    was trying to get it done for edition38 but it aint going to happen oh well..:racer:
  4. HTC
    HTC Active Member
    3,428
    9
    Take a look at this for help choosing injectors
    I'm about to strap on a new turbo to mine. looking at 370bhp hopefully. I have a set of 630cc (60lb/hr) to go on. Should be easily enough at 3 bar for both or our setups, but no harm running at 4 bar. Up to you really. Map will be changed to suit.
  5. jim s3
    jim s3 Member
    321
    i know i have been reading your progress on seatcupra.net and reading up on that hooch that sound like a tool and a half i only hope mine goes that well..already got injectors 755cc ones cant wait to get it on the road :scared2:
