Game over, damaged engine.... Only major damage is the cam
Andrew@A.L.D Jan 12, 2013
  1. Andrew@A.L.D
    3,879
    617
    uprated breather system will be made, get cams sorted and looking into the GTX3576, Need to get them some 1150cc injectors or bigger
  2. Andrew@A.L.D
    3,879
    617
    NEVER !!! lol
  3. Scullies
    Scullies Well-Known Member
    1,543
    657
    Interested to see how you fit the GTX35 in there. My pte6262 is tight, tight like a ducks **** :yes:
    You might have more space as I have a LHD and the brake booster is an issue for the TIP.
    What manifold you have in mind?
  4. Broken Byzan
    13,237
    465
    I like your style, I'd love to change my cams when i change the head, but still waiting on IE for the milder cams to come into stock eventually. I don't want race, needs to be tractable
  5. Andrew@A.L.D
    3,879
    617
    The GTX3576 is the same size as the GTX3076, they both run the same compressor housing, I had to lower my engine 15mm to get it in there.
    I'm not getting a new turbo just replacing the internals and some other things
  6. badger5
    9,510
    2,004
    bigger.... muah ah ahaaaa
  7. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,267
    596
    We need to spin it quicker for the GTX35 - think your diesel crank will hold together :D
  8. Andrew@A.L.D
    3,879
    617
  9. Andrew@A.L.D
    3,879
    617
    Got a call from piper and a new foc cam on the way
    Westy, Broken Byzan and StaceyS3 like this.
  10. Scullies
    1,543
    657
    AWESOMENESS !!!
    So you wont need my fancy paper weight.
  11. Broken Byzan
    13,237
    465
    PHEW, that's good news
  12. Andrew@A.L.D
    3,879
    617
    No mate, I just want to thank you again on the offer as most people wouldn't do that, even someone in Dubai like yourself.
    A true gentleman. Thank you again
  13. Prawn
    11,538
    3,494
    have they explained what caused the failure Andrew? How can you be sure it won't happen again?
  14. Andrew@A.L.D
    3,879
    617
    I have spoken to them and they made sure this cam will be 100% reliable
    Its not going to happen again and explained everything and apologised.
  15. Prawn
    11,538
    3,494
    That's cool, I wasn't trying to be antagonistic, more concerened that replacing like for like without knowing fully why it failled could lead to a very expensive repeat of fortunes!
    Are you able to share with us why it is thought this one snapped so badly?
  16. Andrew@A.L.D
    3,879
    617
    I would rather not on the forum as i respect Piper for what they have done for me
  17. Broken Byzan
    13,237
    465
    Regardless of failure reason, I'd deffo not buy one now, that could have been much worse.
  18. Andrew@A.L.D
    3,879
    617
    Trust me this was not mine or Pipers fault. I would say go out and get them but get them from Piper only.
  19. Prawn
    11,538
    3,494
    oooooooooooh, lets blame Yodel! They're the cause of most things breaking between being made and arriving at the customer!
  20. Andrew@A.L.D
    3,879
    617
    It could of been or it could of been the company i got it off.
    As i said piper have done nothing wrong and they have a great after sales service and i should get a well packed up cam delivered to me by Thursday
  21. Scullies
    1,543
    657
    No worries Andrew, I just can't bring myself to throw these kind of things away. Rather pass them on if someone needs them.
    FYI, the offer stands for everyone.
  22. badger5
    9,510
    2,004
    utterly pointless post...
    it failed on its own without reason........... nope.. it failed for a reason, you choose to not share, which regardless of your motives to protect piper and their foc replacement service for you (understandable) the cause is not being stated, which makes us think its something being hushed up... and may reflect on piper worse than saying what went wrong?
    am i wrong?
    am i alone in thinking this?
  23. badger5
    9,510
    2,004
    do yodel actually deliver goods to destination customers at all???
  24. Dani_B19
    9,321
    390
    I ****ing hate yodel.
    Ive got to admit though, im with bill mate. By not stating the reason for failure people will look upon this as pipers fault!
  25. Broken Byzan
    13,237
    465
    I'd take you up on it if I was sure I could run just the exhaust cam?
    Or anyone know if I can just buy an inlet cam?
    Soo temted
  26. Andrew@A.L.D
    3,879
    617
    Yes there was a problem with the cam but i'm not about to bash Piper on here
    It was a number of things
  27. Sam_
    Sam_ Down under
    3,038
    480
    Material fault? Pretty obvious isn't it? Bad casting?
  28. Andrew@A.L.D
    3,879
    617
    As i said didn't get them direct from Piper, Will from now on.
  29. badger5
    9,510
    2,004
    .......which you wont elude to...........
    something built wrong by you?
    cam material issue?
    Piper Cam failed.. snapped... in use, not on installation (which I have done myself on schricks such was their brittle nature and sensitivity on tightening down the cam caps very slowly and progressively)
    I dont get the secrecy or evasion
    There was a problem with the cam.. Material? Batch problem which snuck out and got resold where it should'nt have? (you say you did'nt get it from piper....)
  30. Andrew@A.L.D
    3,879
    617
    Bad batch sent to one company that shouldn't of gone
  31. Prawn
    11,538
    3,494
    **** luck that you got one from said batch Andrew!
    I wonder how many other people are heading unknowingly towards the same fate!
  32. jojo
    28,908
    3,564
    Just a bad batch of exhaust cams, inlet is fine?
    Glad you got a replacement, any further backup with regards to further damage, or just a brand new replacement cam?
    Either way, it's good to hear your S3 will be back again!
  33. RobinJI
    RobinJI Active Member
    178
    Glad to hear the issue's not as dramatic as it seemed at first. Pretty understandable how a bad batch could be sent out, so I wouldn't worry too much about soiling their name, personally I'd look on Piper more favorably now I know what the issue was, rather than it just being left unknown. Sounds like they're being very decent and professional about sorting it for you. :)
