Gaining access to washer bottle/pump
bambam Apr 8, 2010
  1. bambam
    bambam Member
    123
    My rear wash wipe isnt working (pump makes noise but nothing comes out).
    I have taken the rear panel off the inside of the boot and there is no fluid in here.
    The pump makes a higher pitched noise when trying to operate the rear washer than when operating the front. This suggests to me that it is not picking any water up to send to the rear.
    Am I right in thinking both front and rear washers are fed from the same bottle?
    If so I need to gain access to the washer bottle/pump to identify whether water is being picked up from the bottle.
    So, how do I gain access to this?
    From the top or the bottom?
    It looks like a pain in the **** from the top as headlight needs removing...which seems to be wedged in by the bumper... (its a 2003 2.0 TDi).
    TIA
  2. smudge_don
    smudge_don Active Member
    2,944
    Front and back both use the same washer bottle mate, located under the bonnet in the engine bay
    Your problem is most likely that the hole where it sprays from on the rear wiper is blocked
    Try sticking a needle or something in the hole, see if that unblocks it
  3. bambam
    bambam Member
    123
    Tried that and unfortunately no joy...
  4. drsilviuro
    drsilviuro Member
    121
    I have the exact same problem :( Tried with wd40 and nothing...
    If I activate the rear wiper it sprays the remaining fluid... After that it stops :( No leaks in the car....
  5. bambam
    bambam Member
    123
    I get nothing from the washer jet but can hear the pump making a higher pitched noise to normal which suggests its not picking up fluid.
    Thought/hoped it would be something easy to spot if I could get to the washer bottle/pump arrangement to see whats going on...
  6. redbutcher
    redbutcher Member
    649
    Same problem with mine - I took the small black plastic jet off and then tried the rear washer......and it worked.
    I soaked the small black plastic washer jet in limescale remover for a few hours and then rinsed it and it's been fine ever since.
  7. bambam
    bambam Member
    123
    hmmm, i'll give this a try then before messing with looking at the pump/bottle
    cheers
  8. JohnS3
    JohnS3 Active Member
    3,032
    You have to remove the bumper skin and maybe pop the drivers headlight out to get to the washer pump.
  9. tdisportuk
    tdisportuk Member
    460
    as said previously! bumper off job!
    located on the drivers side
  10. drsilviuro
    drsilviuro Member
    121
    Thanks! That was in my case too! :) Removed plastic washer jet and cleaned it.. and it now works! :)
  11. bambam
    bambam Member
    123
    I'm still yet to find time to take a proper look at mine...will definitely be giving this a try first though :icon_thumright:
