G65 Damaged connection
AudiLeon Feb 28, 2012
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,246
    189
    Our A6 has the ECON light on. Got VCDS on the job and found there was a fault on the G65 sensor. Ordered one and found the car didn't actually have one. It had been removed for some reason.
    So I put it on and it just turns. As if the threads have been stripped slightly. So I cannot get the switch to tighten.
    Is there a way of repairing this without having to replace the aircon radiator.
  2. kite
    kite Member VCDS Map User
    677
    Helicoil might do it.
  3. AudiLeon
    2,246
    189
    I was thinking that, but then I wondered how much the threads need to be damaged for it to work.
  4. AudiLeon
    2,246
    189
    Well I got some equipment from work together. We have similar connections at work. No luck though.
    The threads are too tired. Not sure how to progress outside of getting a new radiator.
  5. kite
    677
    Could a radiator repair place to put a new one in?
