g60leigh build thread. it's gonna get messy
g60leigh Dec 12, 2013
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I have been a member of the forum for a while now, but spent most of my time reading others builds and asking for help and info, I have added a few posts on my projects in the past but nothing to major
    I have been meaning to create a build thread for a little while but my personal build has been a little slow.
    Until now, as it seems to be taking off and things are starting to get MESSY!.
    I will throw together the bits and pieces of my build in here in the hope it is of some help or inspiration to others. It will most likely not be in true chronological order as my memory for dates is appalling.
    I started off with no intention to heavily modify as I loved the S3 in standard form. That did not last too long though.
    Rather than go through the order in which I have added things, here is a list of the spec changes to my car now:
    ENGINE:
    Porsche Alloy Oil Filler Cap & Porsche Alloy Coolant Cap (From ScottB5 Group buy)
    Forge FMDV008 Recirculation Dump Valve
    Revo Stage 2 ECU Map
    Badger 5 V2 TIP with J&R Cone filter and Heat Shield
    TFSI Coil pack upgrade with NGK Iridium Spark Plugs
    Evap removal
    Miltek Cat back stainless steel exhaust
    AH Fabrications V1 front mount intercooler
    Phenolic inlet manifold gasket
    Relentless V2 tubular steel manifold
    Relentless V3 3” Down pipe and 200 cell Sports catalytic converter
    Oil catch can and PCV removal (soon to be replaced with a new one of my own design)
    Titanium manifold heat shield
    Carbon fibre engine cover
    AEM 30-3000 Progressive WMI
    CG Motorsports 5 paddle clutch
    LUK DMF flywheel.
    CHASSIS:
    17" Ronal Avus Alloy wheels
    Neuspeed Front Anti Roll Bar (Poly bushed)
    R32 Rear Anti Roll Bar (Poly bushed)
    Powerflex Poly Dog bone Bushes
    XYZ Coilovers
    Poly bushed Rear Trailing Arms
    Compbrake adjustable Tie Bars
    LCR Brembo’s with B5 330mm 2 Piece Rotors
    ATE Superblue Racing brake fluid
    B&M Shifters short shift
    INTERIOR:
    TT Pedal Set
    S3Dave stainless foot rest
    Ambient Lighting Mod
    LED Interior light upgrade
    Retrofit RNS-D Double Din Satellite Navigation (With Xcarlink iPod connection)
    AEM boost gauge in custom vent pod
    [​IMG] [​IMG]
    EXTERIOR:
    Audi TT Fan Style Washer Jets
    VW Golf R32 Front Wiper Arms & Aero Blades
    VW Polo 6N Rear Wiper Arm & Aero Blade
    VW Yeti Stubby Aerial
    German pressed plates with Audi Sport surround
    Black Plasti Dip door blades and rear bumper trim.
    On the incoming list:
    Performance parameter display – displays gauge info on the OEM DIS – Supreme Technology & Engineering I will do a full write up on this when completed
    BBS RC041 split rims
    Custom oil catch can
    Comfort (1 touch 3 blink) indicator mod
    8P S3 chrome trim modded headlight switch
    Engine rebuild with IE rifle drilled rods, Bosch 550 injectors Stage 4 Hybrid turbo and custom map :D
    Some of my other threads:
    Fan Washer jets and aero blades
    http://www.audi-sport.net/vb/a3-s3-...yle-washer-jet-upgrade-aero-wiper-blades.html
    Gauge pod build
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/163922-pillar-gauge-pod-build-thread.html
    B&M Short Sifter
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/172614-short-shifter-different-option.html
    WMI
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/181839-wmi-help-needed-lots-please.html
    RNS Retro fit Sticky
    http://www.audi-sport.net/vb/a3-s3-...70-double-din-conversion-rns-d-retro-fit.html
    kwistof, Jay A3 and Sandra like this.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,503
    10,567
    Looking forward to reading more on this. :) x
  3. g60leigh
    1,674
    207
    This is the turbo I've got:
    MD421 - Stage 4 Hybrid turbo comprises:
    High Flow K06 Billet Aluminium Lightweight Compressor Wheel
    Re-profiled compressor housing
    Turbo Dynamics designed uprated 360 degree thrust kit
    K04 Large trim turbine wheel with lightening modifications for quicker response
    Re-profiled turbine housing to suit new turbine wheel
    Turbocharger fully blueprinted to motorsport standards
    Max recommended boost: 24-26 PSI
    Estimated Power Output: 340-360 bhp with correct supporting modifications
    Its second hand but only got a few miles on it.
    Seems to be in excellent order but getting it checked prior to fitting.
  4. g60leigh
    1,674
    207
    My new design oil catch can.
    I have fag packet cad designed this. With the intention of mounting it on the side of the battery bracket.
    Pics of mounting to follow once Royal Mail get it to me.
    StaceyS3 and s3dave like this.
  5. Scullies
    Scullies Well-Known Member
    1,543
    658
    That's a fairly large catch can :)
  6. g60leigh
    1,674
    207
    Bigger is better ? Haha
  7. Scullies
    1,543
    658
    that only applies to turbos, and certain parts of the human body :)
    Westy, AVLO, Andrew@A.L.D and 2 others like this.
  8. Dani_B19
    9,343
    394
    Anymore Info of the headlight switch?
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    ^^ In house magpie is at it....lol ^^
  10. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    I think he's wondering how he's getting on fitting the chrome nob to his 8L switch as he attempted it before. Dani, I'll let you know when I got it. :)
    g60leigh likes this.
  11. JimmyH
    JimmyH Active Member
    374
    73
    Looking forward to some more updates.
  12. g60leigh
    1,674
    207
    As Scott says the progress of the 8P headlight switch is in his hands.
    Received the oil tank today. My fag packet cad design is slightly off so will take a little more tweaking than I had hoped but still confident that it will work and be a neat finish utilising otherwise dead space.
  13. Andrew@A.L.D
    3,879
    617
    Nothing wrong with that, here's mine[​IMG]
    bigray, ScottD3 and g60leigh like this.
  14. lorryz
    lorryz Active Member
    139
    29
    \Pretty interested to see how this plays out
  15. Dani_B19
    9,343
    394
    Shut up dave haha. Keep me updated scott.
    ScottD3 and s3dave like this.
  16. g60leigh
    1,674
    207
    Update on the performance parameter display.
    😤 not good unfortunately. I've been working closely with the developers of this and even had a replacement box through but not making any progress. Seems that for reasons unknown this is not compatible with the A3/S3 DIS
    I'm not entirely sure what differs between ours and the A4 or TT ones but cannot make it work. 😭
  17. g60leigh
    1,674
    207
    To get over the disappointment of the PDD. I have tracked down a purchased one of these bad boys.
    Let the fun continue.
    superkarl and Westy like this.
  18. Westy
    Westy Well-Known Member
    17,443
    1,105
    I'm jealous.
  19. g60leigh
    1,674
    207
    Been on the hunt for a long while. Ended up finding two for sale this week.
  20. g60leigh
    1,674
    207
    Scott's progress so far with the 8P headlight switch
  21. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Just reading you spec list is making me think reading this thread may prove expensive !
  22. S3 Paul
    2,825
    107
    So he has broke it?
    Im great at that part of the job... it the next stage that usualy involves duck tape and super glue
  23. g60leigh
    1,674
    207
    Go Scott go!
    Thank you mate. Pics of it installed when I get it back.
    bigray likes this.
  24. ScottD3
    15,164
    1,123
    You want it back?<br />
    <br />
    Paul, Broke it.
    Cheeky.
    Westy likes this.
  25. g60leigh
    1,674
    207
    Yes please mate. I've messaged you. Its a pain in ass not been able to drive at night haha.
  26. Scullies
    1,543
    658
    I don't see a like button anymore, so just wanted to notify you that I like this :)
  27. aterro
    aterro S3 YO
    272
    wheres the other one for sale ?? haha I've been after one for a while too!
  28. g60leigh
    1,674
    207
    PM me I will pass on a contact no
  29. g60leigh
    1,674
    207
    Haldex controller arrived this morning. Along with a few other bits. Wish I was in a fit state to do anything on the car at minute 😭
  30. bigray
    bigray Active Member
    144
    53
    great build so far bud. and would love a haldex controller i need 1 for my golf,
    and andrew any details on that battery like how much and were from please
  31. Andrew@A.L.D
    3,879
    617
    I hope to be selling my Blue controller in the new year
    Its one from ebay ETX20L-BS YTX20L-BS 12V 18Ah AGM Motorcycle Battery
  32. g60leigh
    1,674
    207
    You pipe up with that AFTER I get one lol.
    Shout at me when your selling. I've a few people asking me about one so can pass info on.
    I've also picked up the bluetooth attachment for my xcarlink and a y-splitter for the obd portabd have a bluetooth obd dongle on order to install hidden away in the dash.
  33. bigray
    144
    53
    cheers dude, also be possible when you put it up forsale to drop me a pm. and out of interest you know if this would with after market management ?
    sorry for the the hijack g60leigh
  34. g60leigh
    1,674
    207
    My new haldex controller
    And a little extra spice to add to the build while the engine is spilt.
    StaceyS3, Westy and Scullies like this.
  35. Westy
    17,443
    1,105
    It annoys me so much tht these little blue boxes cost so much still!
    Good work so far Leigh :thumbsup:
  36. g60leigh
    1,674
    207
    I agree that they seem to be so elusive and pricey. Only heard good things so I'm hoping its worth it.
    Would of thought these days a tuner could have a look at one and write their own equivalent code to make an alternative version.
  37. s3dave
    10,110
    736
    Looking good Leigh..power user...
  38. g60leigh
    1,674
    207
    Bit of a quick change in plans and it soon spirals outta control.
  39. g60leigh
    1,674
    207
    Today's delivery so far.
    Ready for rods install.
  40. g60leigh
    1,674
    207
    Quick job for today.
    I'm pretty limited to what I can do at the minute after my spine surgery.
    Grabbed this after looking for a decent car hands free kit
    Was looking at parrot kits etc but was this one was pointed out to me by Scott.
    If you have an xcarlink, get one!
    Literally plugs into the xcarlink box. Plug in mic and pair it up to phone. Job done and as a bonus can bluetooth music from phone too.
