G200 Sensor
Sam_ Apr 26, 2011
  1. Sam_
    Sam_ Down under
    3,039
    485
    Does anyone have a definitive answer for the part number for the G200 sensor for an '02 BAM S3?
    I'm getting the ! ESP symbol up on the dash now and then (and stays till restart) and there's a fault in VCDS that says its duff.
    Cheers!
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Just call Audi mate they'll be able to tell you.
  3. Sam_
    Sam_ Down under
    3,039
    485
    OK will do. I'll post the part number in here once I get it for others searching.
    I usually buy my parts through VW as they're cheaper but I'll get the part number from Audi. Cheers.
  4. Sam_
    Sam_ Down under
    3,039
    485
  5. Sam_
    Sam_ Down under
    3,039
    485
    Not cheap at $280 but it's on order. Mad money for how small it is.
  6. Sam_
    Sam_ Down under
    3,039
    485
    So I fitted and the light still came on :( I think it needs calibrating. I'll do that when I get home although I've read that for some people it worked fine after being sat for a period of time. It's in the car park at work so we'll see when I go to leave...
  7. Sam_
    Sam_ Down under
    3,039
    485
    Damn it. I'm still getting the same error. This time I clear it and it comes back as soon as I turn the ignition on (as does the light). It was fine for about 20km but now it won't go away. I can't login to reset the sensor to 0 and this is what it reads parked up in the garage (which I think is flat!)
  8. Sam_
    Sam_ Down under
    3,039
    485
    Just checked the longitudinal sensor and I imagine this is also wrong....
    I'm guessing this could be wiring then? fantastic.
  9. Sam_
    Sam_ Down under
    3,039
    485
    The plot thickens. I think at some point the bracket holding the sensors has been bent. Would explain the crazy readings.
  10. Sam_
    Sam_ Down under
    3,039
    485
    Straightened the bracket and the lateral sensor now shows 0m/s which is good.
    Longitudinal shows the same still though but no error codes and no lights on the dash so must be all good...
    Inertiauk likes this.
  11. Sam_
    Sam_ Down under
    3,039
    485
