Fuse locations...boost gauge wows...
BigD-a3tq May 26, 2010
  1. BigD-a3tq
    BigD-a3tq Member
    69
    I know theres one in drivers side dash and also 3 on top of the battery cover is there any more?................ the reason i ask?.......
    ...Last week i spliced my boost gauge into the back of the lights switch which worked fine, illuminated when lights were turned on etc, Pukka!
    At weekend as the weather was nice i thought i'd connect the boost side of things, following a guide i attached it to the FPR pipe and poked it through the bulkhead where the bonnet release cable goes through, easy no problems!
    Next i took the under part of the dash off (below the steering wheel) and disconnected all the wiring looms
    (OBD port lights etc..) still fine, P.O.P i thought !
    UNTIL **bang** whilst near the pedals trying to find the boost pipe and piece of coat hanger it was atttached to i saw a spark in the corner of my eye come from one of the disconnected wiring harnesses...Danglies i thought now what! stopped what i was doing and turned the ignition i thought i may have blown and fuse, but no, no problems on the display, result i thought! and carried on.
    It wasn't until i turned my lights on later that night that i got a beep and a warning symbol on the DIS and now neither the boost gauge nor light switch iluminate, after consulting the handbook i concluded i must have blown a fuse so checked all the fuses (drivers dash) but no, nothing blown do i have any fuses anywhere i should check?
    Any advice appreciated!
    Muchas gracias!
    Daz
  2. Dani_B19
    9,251
    375
    Does your interior lights work?
  3. BigD-a3tq
    BigD-a3tq Member
    69
    Hi mate, yeah everything else work fine!?
  4. Dani_B19
    9,251
    375
    So what symbol you got on the dash then?
  5. BigD-a3tq
    BigD-a3tq Member
    69
    at work at mo and cant remember off the top of me head so once i get home i'll have a look and try to describe it.
  6. BigD-a3tq
    BigD-a3tq Member
    69
    [​IMG]according to the handbook the symbol = Bulb failure; dipped headlights or rear lights
    If i put the keys in with the ignition turned on and turn on my lights everything works EXCEPT rear O/S side light, light switch illumination and boost gauge.
    If i take the keys out and put the O/S parking light on, the light switch and boost gauge both illuminate?????
    Is this something the free version of vag-com will pick up??
