Fuse 28 melted?????fuel pump!!!!
darren t Jan 13, 2013
  1. darren t
    darren t Member
    568
    Can anyone shed some light, I have an Audi s3 8l 2003 model I had my turbo off today when I put it back on I decided too pull fuse 28 for fuel pump too prime turbo but the fuse was not blown but melted I changed it and car started ok fuse didn't get hot or melt as yet,what could cause this any ideas?
  2. <tuffty/>
    21,363
    3,927
    It will most likely be because its drawing too much current... this is typically due to it being put under a heavier load than normal... I'd replace your fuel filter if you haven't already... it could also be a sign the pumps on its way out...
    Also check your fuel trims... if they are quite a high additive value on LTFT's then check the FPR vac pipe is in good nick...
