further to my heat loss
hades- May 23, 2012
  1. hades-
    9,481
    646
    been checking the car today as i had heat loss
    theres no return into the header tank
    so my thinking is waterpump ?
    could a blocked matrix cause no return to header tank ?
    still gets upto temp and stays put at 90
    TIA
  2. Wrath
    Wrath Well-Known Member
    1,196
    42
    Ideally if you can get the two pipes off from the heater core then you can flush just the heater core. The pipes were stuck fast on mine and could only manage removing one. I then decided to flush the whole system which was a faff. Had to remove the thermostat to allow the pipework to flow freely.
    My symptoms were, warm air to begin with and then it dropped off. If CC put on High then I'd get hot air but no intermediate. After flushing the coolant I no longer have a problem.
  3. hades-
    9,481
    646
    yeah thats geting done now
    but with the heater blocked would it still have a return to the header tank ?
