Funny wiper issue
Mollygoogle Jun 12, 2013
  1. Mollygoogle
    Mollygoogle Member
    227
    This morning when I jumped in the car it had been raining so switched the wipers on. The wipers then only moved 1 inch and stopped. If I knock the ignition off the wipers go back to park. As soon as I touch the control again it moves 1 inch and stops.Any ideas?
  2. quattrojames
    14,050
    573
    Look in the DIY Guides sticky for "Slow Wiper Repair".
  3. Mollygoogle
    Mollygoogle Member
    227
    I did have a look at that, great write up by the way, but initially dismissed it because all the threads I have read across the net describe different symptoms to me?
  4. quattrojames
    14,050
    573
    Unless it's a relay or switch issue?
  5. Mollygoogle
    Mollygoogle Member
    227
    Ok, I've taken the wipers off. Without them there the spindles move 5-10 degrees then stop whilst straining to keep moving.
    The problem I have now is that even with the three clips removed the trim under the windscreen will not come off! I don't want to break this so what do I do! Can I do the job whilst holding the trim out of the way? I guess not as I can't get to the rear torx bolt on the ECU cover?
    help!
  6. quattrojames
    14,050
    573
    The trim needs to come off from memory, it's a long time since I did it so I can't fully remember how it's fixed. I know they're easy to break, but on the plus side only £20ish I think if you do. I think I got a small pick under one side and used it to lever it out of the small channel in the base of the screen. Be very careful though, better to break the strip than the screen...
  7. Mike_B
    Mike_B Active Member
    533
    47
    Well, I had a bad case of slow wipers and had got as far as sourcing a replacement mechanism - I then found I couldn't get that trim piece off, no matter which way I pulled / lifted / slid the wretched thing. When it started to crack I gave up and decided I'd have to put the job off until I'd got a replacement ready to hand. But, as an interim solution, I took advantage of the slightly increased access to apply some spray grease to the linkages and the spindles. (NOT WD40!)
    The end result of that was wipers which worked again - and a year on, still are. It might just be worth the try - I suspect that you may need to put the arms on to give some manual assistance to the mechanism to get them moving and help the grease work in.
    Mike
  8. Mollygoogle
    Mollygoogle Member
    227
    Guess what, it broke! I hate cars at times
  9. Mollygoogle
    Mollygoogle Member
    227
    Not only has the scuttle trim snapped but the linkage itself has snapped too
  10. Oh dear mine has done this too today so im no doubt gonna have same issues when I attempt the fix tomorrow,
  11. quattrojames
    14,050
    573
    Blimey, lol!
  12. Mollygoogle
    Mollygoogle Member
    227
    i can laugh now but last night I was looking for the jerry can and the matches!
    the wipers worked perfectly one day and then the next day were seized completely solid, I didn't really believe that was possible
  13. Mollygoogle
    Mollygoogle Member
    227
    In a much happier mood now, shiny new (to me) linkage and scuttle trim installed and working. I can't thank Prestige of Stockton enough for staying open late tonight and doing me a great deal on the parts, a big thumbs up from me
  14. Can I be cheeky and ask how great a deal? as I live in Stockton myself?
  15. Mollygoogle
    Mollygoogle Member
    227
    £65 total or both parts. The wiper mech looked almost new!
