Funny Sound From Breaks
vr6gordy Aug 17, 2014
  1. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    My car is starting to make a funny sound from the break disc area on the passenger side when I'm not even breaking .. Took the pads out and noticed on the inside of the disc there is a massive grove and the pad has uneven wear .. Could this make the binding sound that I'm hearing ??
  2. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    131
    check the sliders in the calipar. also piston
  3. vr6gordy
    2,826
    191
    Cailper Is only a year old and pins are all clean and copper slipped
  4. mattyb6
    mattyb6 Active Member
    977
    75
    Check the retaining clip/pin
  5. vr6gordy
    2,826
    191
    Put new clips on yesurday .. As the break pad is not flat on the inside I'm pretty sure it's that making the noise . Discs and pads came from euro car farts.. I've had a few things from them now and are ment to be vag items but there no where near the same .. Gonna buy my parts from audi from now on
  6. sal1m
    sal1m Member
    49
    I had pagid pads from ecp and they were a tight fit,the pads squealed so i changed them for another set, they slipped in comfortably and now no more squeals.
  7. vr6gordy
    2,826
    191
    You might have hit the nail on the head there
  8. vr6gordy
    2,826
    191
    Can a heavily grooved disc make the break pads bind
  9. mattyb6
    977
    75
    Gordy how much were the clips just out of curiosity?
    I used ECP pads and discs on the rear and had no problems
    Just my fronts squeal bad but I haven't changed them since I've had the car in 3 years and they've still got loads of life left in them
  10. vr6gordy
    2,826
    191
    Clips where only a few quid off eBay
  11. vr6gordy
    2,826
    191
    Just had a good look at my breaks and I think I've found out what's wrong the inside egde of the disc has a rusty lip around it and the pad is just hanging over so I'm thinking the sound is coming from there so out with the grinder tomorrow and shave the pad a little
  12. mattyb6
    977
    75
    Might be able to pick up some new discs for about £25 each
  13. vr6gordy
    2,826
    191
    Mine are 312mm so 25 quid sounds very cheap
  14. vr6gordy
    2,826
    191
    Well had all
    The breaks striped down today cleaned them all up piston pushed in very easy so it isn't stuck one thing I did find was when I rotated the wheel just at one point it made a sound so guess the disc is warped I need new discs anyway cos of the grove it them
  15. mattyb6
    977
    75
    Ah mine arnt that big mate
    Your probably looking a little bit more
    Haha I'm just running baby 1.9 brakes
  16. vr6gordy
    2,826
    191
    My mate has an account at euro car farts discs and pads came to 77 quid all in pagid
  17. vr6gordy
    2,826
    191
    All fitted in 2 hours
  18. vr6gordy
    2,826
    191
    Took car out this morning only to find out there still making a catching sound so stripped em down checked piston and there's no rust but what I did forget to do is copper slip the slider pins they where bone dry .. Not been for drive yet but I'm sure I found the problem this time
  19. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Don't put copper slip on the sliding pins, there is a special lubricant that should be put there, best to leave them dry than use copper slip...
  20. vr6gordy
    2,826
    191
    Copper slip has now been replaced with some proper break grease
  21. vr6gordy
    2,826
    191
    Well took car out after swoping over the grease on slider pins and no
    More binding
  22. mattyb6
    977
    75
    Good to here mate
    I'm going to sort my squeak out this week, I think the pads are too right against the carriers so might just need to grind a tiny bit out
