Funny Revs under Acceleration
Wizza Oct 13, 2012
  1. Wizza
    Wizza Member
    750
    15
    Yesterday night was driving down motorway and accelerated from around 70ish up with foot flat on pedal.
    I heard the car rev funnily from around 2k to 4k and then to around 5k but all of a sudden the revs dropped back to about 3k and startes climbing normally again.
    What can cause this proplem or can it just be a one-off? It didn't happen again last night and the car was at optimum temperature.
    Cheers for advice :)
  2. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Sounds like the clutch slipping? Did the revs go up but the car didn't accelerate?
  3. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I think it sounds like a slipping clutch, or a bad misfire.
  4. Wizza
    Wizza Member
    750
    15
    Well I know its boosting correctly but yes Greeny. Revs seemed to climb but at a much faster rate than speed than it does normally.
    I'm sure Clutch isn't slipping as not had any problems before now and no problems today
  5. Wizza
    Wizza Member
    750
    15
    I don't think it's clutch as it only happens every so often if at all. Did it again today under acceleration (4th gear).
    I have a feeling it may be fueling related.
    Also just to point out when turning the car over it makes quite an odd noise as it there is a 'grinding' noise. Maybe starter motor lacking power?
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    Think about it.
    The clutch is what allows a connection between the engine and the gearbox. If the engines revs rise and the car doesn't accelerate it can only be wheel spin or clutch slip.
    Find yourself a wide open space, handbrake on tight with the engine running. Hold the revs at 3K and let the clutch out gently as though you were pulling away; if the clutch slips it's ****ed and get a new one. If it stalls then your wheels were spinning.
  7. Prawn
    11,633
    3,623
    perhaps someone has installed a badass ko4 hybrid that'll happily spin the wheels at motorway speeds like this?
    If not, then your clutch is slipping....
  8. aragorn
    18,577
    868
    Yep clutch.
    They fail in different ways, but "full throttle in 5th gear" is one of the ways to test a worn clutch, and yours has clearly failed.
    In lower gears there is less load holding the engine back, so it revs up without slipping.
    You can try Jardos test and see what happens, or find a nice long uphill stretch and repeat what you did on the motorway, ie 5th gear full throttle around 3k. It might well pass, but it'll only get worse from here. When mine failed, it would sometimes pull just fine, and sometimes it would slip. It seemed to vary from day to day, but the longer the trip the worse it seemed to get.
    I very much doubt it was wheelspin, as even though prawns car is a monster, i very much doubt it would spin its wheels in 5th. Not only that, but in a standard car with an open diff, if it were wheel spin it'd have been pulling all over the road. Given you didnt notice anything other than the revs acting funny, i doubt it was wheelspin.
  9. Wizza
    Wizza Member
    750
    15
    No definitly not wheel spin.
    I hope it's not clutch :( it's only 30,000miles old (if that) and it's single mass flywheel if that makes any difference.
    Does anyone have any clue to the last part of my previous post.
