Funny noises from my S3 (Wheel bearings?)
comdw Sep 18, 2003
  1. comdw
    comdw Member VCDS Map User
    150
    I'm getting some interesting noises from my S3, which I'm hoping are just worn wheel bearings and not something more sinister (and only 6 weeks to go on my warranty!).
    At speeds above 50 its like a constant whirring (more like someone going "oooooooooo"!) noise.
    It becomes louder between 35 and 40 and more vibration in the noise especially when turning - its especially noticeable if I come right off the gas at 40 and allow the car to slow down.
    There also more of a rumbling noise at around 17-20mph (i.e. exactly half of the speeds above).
    Note that the noise remains the same even if I'm not in gear.
    So is it wheel bearings or anything else I should be more worried about??
  2. NWMark
    NWMark Member
    211
    14
    Its either that, the brakes (sticking caliper, or handbrake problem) try using the brakes/handbrake very slightly and see if it makes any difference or it could be a tyre!!
    although from your description it does sound like wheel bearings, try jacking the car up and check for any play in the wheel when gripped either side and 'rocked'.
    Mark
  3. MarkyB
    MarkyB Member
    109
    Prolly worth getting the offending wheel's balance checked before blaming the bearings. I had a similar problem with a buckled wheel on my old Cavalier that I eventually diagnosed by swapping it with the spare.
    MarkyB.
  4. comdw
    150
    actually i've had the space saver wheel on the back left for a few days (not done many miles though) and the noise seems louder since - the proper wheel is back on now.
