Fun tricks with the 8P's
smudge_don Apr 23, 2009
  1. smudge_don
    smudge_don Active Member
    2,944
    Are there any?
    On my Corsa that i had before, you could close the windows by holding the lock button on the key fob, and do something with the lights so that they came on when you unlocked it.
    Any nifty little tricks that i dont know about for the 8P?
  2. APL TDi
    APL TDi Member
    289
    U can open AND close the windows on your blip key. Just hold unlock to open and lock to close.
  3. gixxer600k4
    gixxer600k4 Member
    692
    you can get a vagcom n set it up so if you brake hard, hazards come on, unlocking it can turn lights on n locking it will put lights on n turn off after say 20 seconds
  4. Wai-Fan
    Wai-Fan Member
    530
    You can make the doors lock when your going faster than 10mph or something. Also, the doors will unlock when you switch the engine off and take the key out.
  5. WiZBiT
    WiZBiT Member
    437
    Theres a mini sun visor between your big ones lol, found that by accident :)
  6. NHN
    29,352
    1,720
    Don if you got your **** down to me I'd code these things for yer or see whats already on, thought we'd done some anyway mate, msn
  7. dc240969
    dc240969 Member VCDS Map User
    925
    and there storage bins under both front seats
  8. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    Can
  9. Boydie
    3,450
    588
    Can you retrofit one under the passenger seat?
    I thought you needed the coming home function for the front lights to turn on upon arrival to the car?
  10. 330_2_S3
    330_2_S3 Member
    243
    Yeah my storage bin under the passenger seat on my S3 is missing too :(
  11. RS84
    RS84 R15 - TDI Power
    168
    I'm pretty sure I read somehere that you can get the current speed in digital format to appear on the DIS... anyone know how to do that?
    Or how to access system stats using the climate control display/controls?
  12. WiZBiT
    WiZBiT Member
    437
    Uhm, i can get my Speed in Digital just by flicking thru the options on the stalk.
  13. APL TDi
    APL TDi Member
    289
    You can get an annoying bleep to go off when you exceed a speed that you set. Not seen seen a digital speed readout, but ut might be cool?
  14. RS84
    168
    Really? What's the menu option called, is it only available when moving or something? ... I must be missing something!
  15. pdv40
    pdv40 Member
    187
    Probably is only when moving but it's the third "screen" on DIS, so scroll through comp 1 & 2 and the next screen should be digitial speed readout, followed by the menu
  16. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    will my 06 sline do that or is it only the new models ....
  17. gixxer600k4
    gixxer600k4 Member
    692
    its only on the newer ones i think, i know my 2003 8p doesnt have it n i think it only came in in 2006 possibly, but i could be totally wrong!
  18. biggiep
    biggiep Member
    156
    think its 2008 or after that has the digital speedo but I might be wrong.
  19. gixxer600k4
    gixxer600k4 Member
    692
    i got a special button on mine which makes it do this!:yahoo:
  20. pdv40
    pdv40 Member
    187
    Mine's an 07 S-Line and it does it, so I would have thought an 06 does. Just click the thumb button on the underside of the right-hand stalk.
  21. pdv40
    pdv40 Member
    187
    Can this be retrofitted? :undwech:
  22. 10blazin
    3,301
    Cool gona give it a go later ...
  23. gixxer600k4
    gixxer600k4 Member
    692
    cant be that hard can it? lol
  24. 10blazin
    3,301
    lol .........
  25. HotboxDeluxe
    HotboxDeluxe automatic
    1,134
    My '06 does it, it's in the menu somewhere. Have a speedo in km/h and can set the digi speedo to read in mp/h, which I like :yes:
  26. TripleD
    TripleD Audi S4 Avant Owner Team Mythos Audi S4
    695
    242
    43
    When I first got the car the temp for the climate was linked so you turned one and the other matched, although now it doesn't, and I haven't read the manual to see how to make it do that again! :blahblah1:
  27. wesley
    wesley Giac Extreme+!! Lovin it
    350
    23
    Just hold the auto button in for a couple of seconds.
  28. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Audi S3 quattro Manual
    1,137
    600
    I like the fact the climate control is dependant on who's key is in the ignition.. I like it toastie warm where as my girlfriend like it cold. But we never have to adjust, as she just uses her key and it remembers temp's etc.
  29. 10blazin
    3,301
    didnt know that ...thats pretty good ........
  30. smudge_don
    2,944
    i found the hazard one really annoying when i had the courtesy car
    how do you do the lights? not that i would probably ever use it....
    i defo want this, the courtesy car had it, mine doesnt do it
    you what? :shrug:
    :whip:
    mine turns into a briefcase like on secret squirrel
    thats pretty cool
  31. WiZBiT
    WiZBiT Member
    437
    There is a mini sun visor, right behind your rear view mirror ;) Total waste of plastic but cool to find :)
    auto locking function is done via vagcom, as with many of these little "tricks"
  32. 10blazin
    3,301
    smudge in front of the rear view mirror up top is a little visor you can pull down its above the mirror in the trim ...its to create a solid line of shade if you have both sun visors down ....
  33. NHN
    29,352
    1,720
    Most of the posts above about will my car do are answered simply by 2 things, one is the features are relative to the year of car, the cluster fitted & the coding of Advanced Comfort Menu's etc aswell, the speedo in the DIS started from about 06-07 onwards, the advanced features like controlling lights, wipers etc also are related to these things, also if you have the full on DIS with 06 onwards car then flick through the menu's & you might see the speedo option, if not there then might be as above, the auto feature of the climate control to control both sides IIRC was just hold the AUTO button for few seconds & this returns to drivers side control of both.
  34. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
