Full LED Headlights Vs LED daytime running lights
ahfh1 Sep 25, 2013
  1. Daveotto
    Daveotto Well-Known Member Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,764
    3,900
    I understand the principle of less light scatter with yellow light but when you mix the yellow light from fogs with the far stronger whiter Xenon light the white light dominates, even in the foreground where the fog lamps are supposed to be working. The one time I have experienced fog when driving with xenons I noticed no difference/benefit when I put my fog lights on and visibility was around 100M through a thick fog patch.
    The xenon's even in fog are far better for seeing and being seen, than standard halogens and not having Halogen fog lamps cannot be an issue if you don't get them when ordering LED's
    To be honest I doubt I will ever turn on my front fogs now as current experience says xenons are good in there own right in fog for seeing and being seen, and I am changing the lamps purely for the aestheitcs when you lock and unlock the car, unless someone convinces me there is a genuine safety reason not to do so
  2. the_lecht_rocks
    the_lecht_rocks Well-Known Member
    704
    274
    Do you get fogs with the xenon light as standard and no fog with LEDs....?
  3. Daveotto
    2,764
    3,900
    yep, can't see any fog lights in any S3 pictures and this is the quote from the brochure "also includes additional air intake funnels in place of the front fog lights" and all other A3's I have seen with xenons have halogen fog lights, including mine.
  4. the_lecht_rocks
    704
    274
    thought as as much, I've gone led but not sure if there's any performance advantage. I like the blue white of xenon personally....
  5. paullowther
    paullowther Well-Known Member
    739
    445
    Lmg and i want it now like this.
  6. the_lecht_rocks
    704
    274
  7. paullowther
    739
    445
    They do both look very white, unlike the xenon blue and the halogen yellow
  8. paullowther
    739
    445
    Just found a review from a German bloke on another forum who talks about his impressions after 1500km with the car.
    Loosely translated - his impression of the LED headlights.
    The LED lights have really impressed me. Optical 1a anyway, I find it also very functional. Curve light, illumination of the road, etc. I really like. Not a quantum leap to the xenon in S3 8P, but I regret not having taken them.
  9. snakehips
    snakehips Well-Known Member
    735
    261
    They don't actually swivel on bends like adaptive Xenons though do they?
  10. paullowther
    739
    445
    I believe they do. They also extend their range when travelling over 68mph.
  11. snakehips
    735
    261
    Yes I'm aware of the extended range and the junction lights etc, just wasn't aware of any moving parts or anything that that adapts on bends. If they do then that's just a bonus!
  12. paullowther
    739
    445
    Collegeboy09 and Toadoftoadhall like this.
  13. jet_andy
    jet_andy Active Member
    168
    30
    It may just be done electronically, by switching on and off different LEDs?
  14. jet_andy
    168
    30
    I wouldn't say fog lamps are yellow, just that they are the colour of standard, inexpensive halogen bulbs. Years ago you used to see real 'yellow' headlights, supposed to reduce glare I think, but they didn't stay around for long. Not sure they're even legal now.
    You can sit for hours looking this up on the web, with varying opinions, but most seem to concur that 'yellow' is not necessarily better. You get less glare and reflection, but you're putting less light out in the first place.
    I saw one post that said they were 'yellow' by design.
    If that's the case, why do they not use 'yellow' fog lights with LED headlights. Fog lamps are gone and replaced with 'all-weather' lights. It states these are in a separate housing - are they still LED though? :confused:
  15. snakehips
    735
    261
    I never quite understood what the all weather lights actually are. If they really are "all weather" then why are they not the default main lights and the rest could be thrown away?
  16. paullowther
    739
    445
    Pictures of LED lights!
    Lmg likes this.
  17. snowfree52
    snowfree52 Full LED baby !
    522
    125
    43
    no they don't but there are LED that switch on when you turn
  18. the_lecht_rocks
    704
    274
  19. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    Firstly, I understood the reason for fog lights is to turn your dipped headlights off and just have sidelights & fogs. As the lower position of the fogs is meant to illuminate the road & verge beneath the layer of fog so as not to reflect back off the fog droplets, dazzling the driver.
    The LED headlights are on a matrix system, which to me means it will illuminate individual chips (LED's) to achieve the desired cast of light. Tied in a front mounted sensor it will reduce the dazzle to oncoming traffic, which everyone moans at with Xenon drivers.
    I had the bendy xenons in a V50 prior to my A3. I miss the bendy feature and the light output as I am quite disappointed with the A3 xenons - especially high beam as this is more of a narrow hotspot than a broad spread.
    I hope I have enough pennies in the pot to spec LED's on my next Audi which I aim to get in a years time.
  20. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,529
    1,149
    You can spec adaptive xenons on the A3 no problem... I really like them tbh, and they seem to do a pretty good job of not dazzling people from the looks of the beam height
  21. thesmileyone
    thesmileyone Active Member Gold Supporter Audi A3
    412
    If xenon plus are standard on S-Lines then why are they a £1500 option for S-Line models?
  22. arad85
    arad85 Active Member Team V6 Audi S5 Black Edition
    732
    238
    43
    They are standard and not a £1500 extra (in fact, I don't know what you are looking at that is a £1500 extra) The s-line option is £295 for adaptive headlights. You can't add the adaptive headlights to LED lights hence the option in the brochure (PXA) is: Adaptive headlights with Xenon Plus headlights.
  23. Kingfisher
    Kingfisher Active Member
    267
    LED headlights are £1500 extra, or were on the Audi site about a week ago.
    Like front fogs, seems no S3 has them ( irrespective of headlamp style) as the space is used as an additional air intake.
  24. arad85
    732
    238
    43
    Brochure price for LEDs is £795 - can only add to the s-line and s3. LED light package can be added to the SE/sport for £2k but comes with Light and rain sensor package (PU8) and Interior lighting package (QQ4)
  25. Kingfisher
    267
    yep, just seen that!
    I wouldn't have been looking at anything other than S or possibly S Line : )
  26. Rick Draper
    Rick Draper New Member
    Does anyone know if the rear lights are different if you spec LED headlights?
  27. the_lecht_rocks
    704
    274
    no, stay the same sad faced strip LED.
  28. cemerson
    4,529
    1,149
    They do change, not from Xenon but from Halogen they do. I think Xenon and LED headlights share the same rear lights.
  29. Louay
    Louay Well-Known Member
    1,114
    516
    Any pics to clarify?
  30. cemerson
    4,529
    1,149
    Well, halogen doesn't come with LED rear lights for a start, as they are included in the Xenon light pack. No pics though, no.
  31. jet_andy
    168
    30
    Pics in this thread
    Louay likes this.
  32. Rick Draper
    Thank you for the info. I just wanted to check as on my current 1 series BMW fitted rear lights with light bars when Xenons were specked over halogen lights. I just wanted to check that Audi did nothing similar to the rear lights when going from Xenon to LED. Especially as I spotted a R8 with rather fancy rear indicators a few weeks ago. They were like the nightrider light, flicking from inside to out like a arrow.
  33. cemerson
    4,529
    1,149
    Yep, those are just on the R8. Someone on here ages ago was talking about trying to mod his A3 lights to do the same though.
  34. Kingfisher
    267
    must be somebody with electronic design experience who could fix that ! I'd certainly go for such a mod !!
  35. paullowther
    739
    445
    It's known as a 'sweeping' indicator and yes, I want them!
  36. ivicyrusivi
    ivicyrusivi Active Member
    157
    Ditto, sweeping indicators would be the nuts!
  37. paullowther
    739
    445
    DAYYMMMMM
    Fragup likes this.
