Full bypass relay kit wiring from TowEquipe
acano Mar 12, 2010
  1. acano
    acano Member
    108
    Don't suppose anyone has a copy of the wiring diagram for the bypass relay from TowEquipe? i've got the wiring kit but as i did not buy it from TowEquipe i can't access the pdf files.
    thanks Tony
  2. BILKO1
    BILKO1 Member
    301
    I to would like this.
  3. scott b
    scott b Active Member VCDS Map User
    1,254
    its a ryder unit, which is what i use when fitting towbars
    if you look at the unit itself it says which each colour is and where it needs to conect to
    wire the unit behind the right hand lamp, run a wire to the left hand for the indicator and to the left hand sidelight
    left hand indicator: grey/blue or green/blue (just check with test light) this goes to yellow wire on the relay
    right hand indicator: black/green this goes to the green wire on the relay
    brake light: black/red this goes to the red wire on the relay
    fog light: grey/white this goes to the blue wire on the relay
    left side light: grey/black this goes to the black wire on the relay
    right side light: grey/red (only wire left apart from brown, just test if its not grey/red) this goes to the brown wire on the relay
    reverse: blue/red this goes to the grey wire on the relay*
    * reverse is only used if fitting twin electrics or 13pin socket
    if there is 2 grey wires on the relay 1 goes to reverse and the other goes to earth, doesnt mater which grey wire does what, if theres only 1 grey wire, it goes to the reverse light
    white wire on the relay goes to earth (body)
    youll also need to power the relay, i take a feed from the rear cig light as its rated at 30 amps, but fit an inline fuse, 15amp inbetween the relay and the cig lighter wire, the live is the red wire or red/white from memory, not brown. the live feed goes into any of the + ports (choice of 2)
    the wires from the towing socket go into the relay ports which tell you which colour to put where, the white wire goes to earth (body).
  4. acano
    acano Member
    108
    Could you tell me where you run the positive when you say the cig lighter how/ where do you run the wire? I know it sounds daft but if there is an easy direction then advance info would be appreciated
    thanks Tony
    A4 B6 2.0 SE
  5. scott b
    1,254
    is your car a saloon?
  6. acano
    acano Member
    108
    Yes the saloon, by that it hasn't a cig lighter in the boot:crying: so from your PM I need to run the positive from the fuse box:scared2:
    I assume the only way is by stripping half the trim along the door sill :unsure:
    thansk Tony
  7. scott b
    1,254
    nah, from memory you can just tuck the wire under the plastic trim, to get a live feed from the fuse box, i get a pre wired fuse holder then put a male terminal (blue one) on the end of it and push it into a live terminal in the fuse board. save cutting into wires and is easier
