Full brake fluid change
Goubo1 Aug 24, 2013
  1. Goubo1
    Goubo1 Well-Known Member
    958
    297
    I'm having to replace my front discs I thought I would replace the fluid as well so I bought some rbf600 as read on here it pretty good,any one any tips on changing the fluid as I've read about people flipping the seals on the master cylinder
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Buy an Ezibleed kit and an 11mm spanner and it's a fairly simple job.
    Goubo1 likes this.
  3. Goubo1
    958
    297
    ill go halfords tomorrow and buy one I see they are only £20
  4. Westy
    17,443
    1,105
    Yeah cheap and the easiest way to bleed brakes. You connect up the Ezibleed to pressurise the system then you go roun each calliper and crack the bleed nipple with an 11mm ring spanner to bleed them.
  5. Goubo1
    958
    297
    i have 996 4 pot calipers on the front are they 11mm too do you know mate ?
  6. Westy
    17,443
    1,105
    If they are brembo then yes they should be.
    Goubo1 likes this.
  7. Goubo1
    958
    297
    cheers mate
