Fuel trim help please.
g60leigh Sep 27, 2012
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I have had the engine check light come on twice now.
    When checking with vcds I get the error
    17544 - fuel trim bank 1 (add)
    P1136 - 35-00 - system too lean.
    After the first time it came up I changed the MAF for a brand new genuine one. Thinking this would be the problem. However got the error again yesterday.
    I have also recently replaced the MAF plug with one I got second hand as the one on the car had broken an was held on place with tie wraps. I have a good connection and all of the wires were soldered and sealed with get shrink.
    Can anyone suggest what could b causing this? Am I barking up the wrong tree with the MAF?
    Thanks.
  2. Lewis583
    956
    91
    I'd say vac/PCV pipe leaking. There are some under the inlet manifolds that are favourites for perishing/splitting.
  3. g60leigh
    1,674
    207
    I have replaced most if them with silicone not so long ago actually so could well be the culprit. I did double check anything not replaced was in good order and all connections were tight but bet I have missed something.
  4. g60leigh
    1,674
    207
    Had a look at hoses and found one with a nice pair of splits in it. Sealed it up with some silicone repair tape. Which seems to have done a good job of sealing it.
    Only done a few miles since but no sign of error code.
    Fingers crossed it is all it needs.
