Fuel Trim; Bank 1: System Too Rich
johnone Dec 20, 2010
  1. johnone
    johnone 5th Gear
    26
    Hi all,
    Just wondering if anyone has encountered these two DTC's before:
    16485 - Mass Air Flow Sensor (G70): Implausible Signal
    P0101 - 35-00 - - ​
    16556 - Fuel Trim; Bank 1: System Too Rich
    P0172 - 35-10 - - Intermittent​
    ESP light on
    After 4 or more starts with ESP light on - CEL comes on
    A brief background - Early December (6th) I replaced the MAF due to similar codes and the ESP (traction control) light on.
    All was well for a few weeks until these codes appeared:
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-00 - -
    P0101 - 35-00 - - Intermittent​
    This time I checked for vacuum leaks and found a split in the brake servo hose - right next to the master cylinder.
    So I ordered a complete new brake servo hose (2 parts) and replaced.
    All was well for 2 days and now I get the above codes (P0101 & P0172) with the ESP light on.
    Any ideas?
    Thanks​
  2. thorsy22
    thorsy22 Member
    308
    System too rich code is likely to bring on the engine light, possibly the maf fault too.
    Replace the MAF with a genuine Audi/Bosch one and should clear those 2 fault codes. As for the ESP light, are you sure it's not disabled as there is no fault codes relating to that system.
    Have you tried clearing all dtc's?
    Edit: You say you replaced the MAF was it a cheap ebay one or a "proper" one?
  3. rusty s3
    rusty s3 Member
    64
    esp light comes on when maf is unpluged and engine is started.check the maf plug and wiring to the plug.
    this would also bring up these codes.may well be a faulty maf?
  4. johnone
    johnone 5th Gear
    26
    Yeah I replaced the Hitatchi MAF with a genuine WV/Audi Hitatchi 06A 906 461B MAF - £100
    It is definitely connected correctly.
    The ESP light comes on as a result of the ECU detecting a rich running condition - I imagine to reduce power and protect the engine from damage?
    I think the next step is to do a full log of blocks 003 / 031 / 032 from cold to running temp to see what the values are for the MAF and Lambda sensors.
    I did run a quick log yesterday on tick over - cold and measuring block 031:
    HTML:
    TIME  	Lambda 	Lambda
    STAMP	Current   Specified
    248.73	1.999 	0.998
    250.16	0.9971	0.9971
    251.47	0.9844	0.9971
    252.8 	0.957 	0.998
    254.3 	0.9941	0.9971
    255.71	0.834 	0.9971
    257.08	1.999 	0.9971
    258.51	0.9482	0.9971
    259.88	0.9346	0.9971
    261.2 	0.9033	0.9971
    262.57	1.999 	0.9971
    263.88	1.999 	0.998
    265.08	0.9268	0.998
    266.51	1.999 	0.9971
    267.85	0.8496	0.9971
    269.28	0.9824	0.9971
    270.59	1.999 	0.998
    271.84	0.8467	0.9971
    273.02	0.8535	0.9971
    274.3 	0.918 	0.9971
    I guess at -6 oC you could expect a value of 1.999 for lambda on choke!?? But I doubt it.
    I think when I get to run a full test with logging - it may show the front O2 sensor is at fault.
  5. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Do some logging, that's all over the joint. I would imagine that 1.999 is the maximum possible value so I would suspect the Lambda is fried.
  6. johnone
    johnone 5th Gear
    26
    Hi all,
    Got a chance to go for a drive today and get some logging done for measuring blocks 003 / 031 / 032.
    To start I cleared the existing fault codes in Engine and ABS controllers.
    Setup logging and went for a 30 min drive - in varying traffic conditions - with a burst on the dual carriageway.
    Everything was running perfectly until around the 23 min mark (3/4 along the graph) when having set off from some traffic lights the ESP / Traction Control light came on.
    Having looked through the logged data - a rich condition was encountered with a 0.79 Lambda value at 1436.81 (Time Stamp)
    However, I am still at a loss as to the cause of the fault!
    The Fault codes logged were as before:
    P0101 - 35-00 - -
    I have attached graphs for different measuremets:
    Lambda Current vs Specified
    Lambda Adaptation Values
    Air Mass
    Engine Speed
    To me the Lambda values seem extreme - does anyone else get lambda values of 1.999 in group 031?
    I can only think that the Pre Cat Lambda sensor is on its way out!
    Any help is much appreciated!!!
  7. badger5
    9,599
    2,060
    intake airmass has a max scale of 80g/s? do I read that right?
    oh hang on, this is a 1.6 engine?
    presuming the blocks are the same.. Not plugged into a 1.6 I can think of..
    block 001 would be pegged at -25% fuel and block 032 fuel trim would be pegged at an equally large negative number I would guess if it thinks its too rich and has been pulling fueling out..
    IF this is actually the case and not a false sensor reading, then I have seen this once before and it was a blocked fuel pressure regulator which could not regulate the pumps pressure to 3bar..
    just a thought
  8. johnone
    johnone 5th Gear
    26
    Yeah its a 1.6 8v BFQ.
    MAF was replaced only a few weeks ago - and it is consistent with the engine speed on the charts below.
    Blocks 032 measure Lambda (Idle) Self-Adaptation and Lambda (Partial) Self-Adaptation respectively.
    Both of which register a value of 0 - with Lambda (Partial) Self-Adaptation decreasing from 0 to -0.4 / -0.8 / -1.2 / -1.6 over a 30 min run.
    Should the pre cat sensor be reporting back values of 1.999?
    Thanks for the info BTW. :)
  9. badger5
    9,599
    2,060
    on steady cruise precat lambda should be 1.00, on overrun yes it will go 1.999 off scale lean as injectors are switched off on overrun.. but only on overrun... cruise should have some activity
    block 001 shows the instantaneous lambda correction so look at this under steady cruise..
  10. johnone
    johnone 5th Gear
    26
    Quick update...
    Issue seems to be resolved - Thinking it may be the lambda sensor that is at fault (possibly dirty) I purchased a can of CataClean CataClean Global Ltd..
    Having put this through my tank - 10 / 15 mile drive - I am happy to report no further DTC's have appeared!!! :w00t:
    I did take a log of block 001 which ranged from -14.1 to 17.2:
    Engine Speed:
    Lambda Current vs Specified:
    Group 032 Lambda (Idle) and Lambda (Partial) Self-Adaptation values are 0.8 and -0.4 respectively.
    I think the pre/post cat sensors may have been reporting inaccurate values and the ECU has been adapting incorrectly.
    Thanks for your help! :thumbsup:
    :kissmyrings:
  11. johnone
    johnone 5th Gear
    26
    Hi All,
    It seems the problem has not been resolved!
    Got the following DTC's this morning after about 5 mins of driving:
    P0130 - 35-10 - - Intermittent
    P0101 - 35-10 - - Intermittent
    I am starting to think its the front O2 Sensor - I hope its not tho - nearly £100 to buy and a pain in the backside to replace!
    Any ideas on things to check?
  12. johnone
    johnone 5th Gear
    26
    UPDATE: happened again this morning after 5 mins of driving!!! :-(
  13. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    that nothing mate my car just failed mot coz i got that reading at 5.400 should of been 0.300 my must be totaly fried lol
  14. johnone
    johnone 5th Gear
    26
    Hi All,
    Found the issue - Vacuum hose from just before the throttle body to the intake manifold was off!
    Shoved it back on and all is well!!!
    I guess the DTC's were correct and did point me in the correct direction.
    MAF error recoded due to un-metered air being drawn in to the system and consequently implausible values being generated.
    Rich running condition detected as the ECU compensates for the un-metered air.
    Lambda error due to the additional air and compensation with fuel mixture.
  15. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Well done, glad your sorted...
  16. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Nice one mate, glad you got it sorted, these bloody vacuum and boost leaks cause no end of trouble for us dont they!!!
  17. johnone
    johnone 5th Gear
    26
    -- Update --
    This error tuned out to be a clogged throttle body.
    I had the car booked in at a Garage in the Wirral called Discount VW Audi - Very good service!
    This cleared the errors and the ASR & Engine Management light have been off.
  18. Welly
    10,696
    130
    Happy days, glad it's sorted. Vac hoses on NA cars are a right pain - I remember those days, and don't miss them.
    Now I have vac hoses on turbo motors instead.... Yay....
  19. Jaggt
    Jaggt New Member
    Hi, I know this is an old thread but wonder if anyone could help. I have the exact same problem with our beetle which I believe has the same engine. What program are you using to log this data and where could I get it from.
    Our car also smokes quite badly when stuck in stop start traffic for more than 10 minutes, but is ok again once under way?!? Wonder if it's related?
    I've cleaned out the throttle body already, when I replaced the intake pipe (£95 from the main stealer!) which had a crack in and was hoping this was the cause. Have recently changed the O2 sensor, maf sensor, coolant temp sensor and many other bits but still have the same issue.
    Please, somebody help!
    Many thanks in anticipation.
    James.
  20. [Dave B]
    [Dave B] Daddy
    2,027
    145
    What year is the car?
  21. Jaggt
    Jaggt New Member
    It's a 2001
  22. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Check the FPR isn't clogged, mine was which caused the code and rich running in my car,although it didn't cause smoking. I expect they were using VCDS to log the values.
  23. Jaggt
    Jaggt New Member
    Thanks for the reply. I have checked the regulator. Looked clean but will check again.
    Yes the smoking is a real mystery. Just hoping it's not more serious than a vacuum leak.
    Do you know where I can get vcds? And does it require any special leads?
  24. sinbrad
    sinbrad New Member
    Did you resolve this issue as my missus has a beetle doing the same and its driving me nuts (and she is)...
