Fuel System Too Lean - Bank 1 and Cylinder 3 misfire.
TDIQ Jul 9, 2010
  1. TDIQ
    TDIQ 8L > 8P > 8V
    777
    My car's been acting up with a misfire.
    I've changed the coilpack for a brand new one, and cleaned the MAF this morning, but I'm still getting an error with Vag-Com saying bank 1 fuel system too lean, and that cylinder 3 is still misfiring.
    The car's down on power and running rough. What could it be? I was told it could be the spark plugs have been fouled from the misfire and also to change the leads.
    Any other ideas?
  2. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Changed spark plugs, cleaned the thottlebody and MAF. Still same problem.
    Thinking it could be the HT lead but I've also heard it could be lambda sensor, but I don't see why this would give me a misfire on cylinder 3 only. Any thoughts, anyone?
  3. badger5
    9,578
    2,040
    what airflow does it log
    maf under reading also causes apparent lean condition
    block 032 will be +25% i guess
    what figures do you have?
  4. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Thanks for the reply.
    What's the best way to log airflow? Just drive about logging the MAF readings?
    The thing is, as it's only cylinder 3 misfiring, would it be something like the MAF as surely that would make all cylinders misfire?
  5. hharry100
    hharry100 Member
    49
    Hey aaron It sounds like you may have a clogged/fault injector, this is the same problem i had and i bought a new bosch injector from euro***parts dont forget you should also change the seals when you remove the injector rail, i think the seals are only available from audi.
  6. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Thanks for the reply Harry. I'll have to check if it's a fuel injector, but I've done a log in third gear up to pretty much the redline that could perhaps rule something out.
  7. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Bill your last post isn't coming up on my phone, would you mind posting it again?
  8. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    have you considered the fuel pump may be on it's way out? when mine was doing this the engine bay was roasting to. (more than usual)
  9. big_mo
    big_mo MOSES
    137
    I also have the same.... bank 1 fuel system too lean. I have been to my mate and changed the air maf is well as cheacked all hoses. Still no joy
  10. TDIQ
    TDIQ 8L > 8P > 8V
    777
    The thing is, if it were the fuel pump surely it wouldn't affect just a single cylinder? It's only cyl. 3 that's the problem, so I guess it could be the HT lead or injector, which are the next things for me to try. The MAF readings seem ok, and surely that would affect all cylinders as opposed to one. I've changed the plugs and coilpack, so that's no worry either.
  11. fran-s3
    1,103
    True it effected all my cylinders! Ok cool well it's not that then lol. Yeah HT leads coil pack or spark plug would be my next bet...
  12. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Finally got a set of HT leads after ECP 'lost' them in the warehouse. Turned out it was the leads, which is nice as an injector from ECP or Audi was about £120.
    Thanks for the help everyone :D
  13. jimmp
    jimmp Member
    194
    sorry to bring this up again as it has now gone down the list-
    Conversely, I get "system too rich bank 1" fault codes every month or so. Anybody any idea what this could be...?
    JimP
  14. big_mo
    big_mo MOSES
    137
    I have the same problem mate.
    Changed the air maf and cleaned the throttle body and realigned it deleted the code. Lasted a week till it poped up as i was going down the M40 at 80mph.
    Back to the drawing bored for me.
    Some one told me maybe a lambda probe
  15. Matt82
    Matt82 Active Member
    2,365
    do you have a misfire with that too?
  16. big_mo
    big_mo MOSES
    137
    No i only get bank 1 fuel system too lean
    No misfire
  17. Matt82
    2,365
    bank one is lambda 1. its trying to lean the mixture and cannot lean it any further
    basically the exaust is too rich... i think you have a boost leak richening up your mixture
  18. jimmp
    jimmp Member
    194
    Thanks Matt82,
    where should we look for that...?
    JimP
  19. Matt82
    2,365
    almost any boost leak will have oil/gunge sprayed out from the leak
    prime suspect is the breather hose under the inlet manifold
    second id look at the connections into and out of the intercooler
    then around the compressor side of the dv.
    anywhere that sees boost really.
    lots to check tbh
  20. jimmp
    jimmp Member
    194
    Thanks for that- I'll have a look tonight.
    JimP
  21. badger5
    9,578
    2,040
    can you get it logged?
    cleaning a tired MAF rarely rejuvinates it
    a low g/s reading would confirm whilst logging.
    i would get this done first before you spend hours chasing other things where this is the most common cause
  22. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Whats happening on this site? loads of old posts coming up??
    EDIT: just read spammer.....:gun2:
