Fuel System to Lean - what is the cause?
IanL-S3 Nov 25, 2005
  1. IanL-S3
    IanL-S3 Member
    923
    Hi
    My car 2001 S3 210bhp.
    I had the yellow engine warning light come up on my dash last week. I ran Vag.com and this was the fault
    Address 01: Engine
    Controller: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    WAUZZZ8LZ11000460 AUZ7Z0A1825361
    1 Fault Found:
    17536 - Fuel Trim; Bank 1 (Mult): System too Lean
    P1128 - 35-00 - -
    Readiness: 0000 0000
    I cleared it and it came back 3 days later.
    The car seems a wee bit lumpy when sitting at say 40 in 4th. I.e its slighly surging. Barely noticable, but as the driver and with the yellow warning light there i notice it.
    So...what i am asking is..
    Does anyone know if this Is a MAF fault or one of the other sensors?
    If it were summer i'd happily tinker around under the bonnet, but being sub zero i'd like to get a spare part and fit it before my fingers fell off /ubbthreads/images/graemlins/smile.gif
    Cheers in advance
  2. HTC
    HTC Active Member
    3,428
    9
    My guess would be either low fuel pressure or a faulty pre cat lambda probe.
  3. IanL-S3
    IanL-S3 Member
    923
    Cheers HTC
    Excuse some daft questions coming up!! I had a clio 1.4 for 9 years prior to this, so everthing cost a fiver to replace and just popped off and popped on! /ubbthreads/images/graemlins/smile.gif
    Low Fuel Pressure? Would that be the pump on its way out?
    Pre cat Lambda probe - i assume this is an easy replacement?
  4. madvw
    madvw Active Member
    2,489
    one of the dangers of a faulty MAF is lean fuelling.
  5. IanL-S3
    IanL-S3 Member
    923
    thanks - will clean MAF and then go through the process elimination (nothing to do with my bowels) /ubbthreads/images/graemlins/tongue.gif
    cheers for the replies guys /ubbthreads/images/graemlins/beerchug.gif
  6. RichA3Turbo
    5,089
    If its chucking error codes, and it IS the MAF, cleaning it wont help as its too far gone!
  7. IanL-S3
    IanL-S3 Member
    923
    Rich Thanks once again. Will get one ordered ASAP!!
  8. RichA3Turbo
    5,089
    Im not saying it IS the MAF... But its a likely cause. Best get the codes checked.
    Rich
  9. IanL-S3
    IanL-S3 Member
    923
    sorry must learn to read properly!! Cheers /ubbthreads/images/graemlins/smile.gif
