fuel smell???
A3tell Apr 21, 2011
  1. A3tell
    A3tell Member
    239
    as above, i seem to have a rather strong fuel smell on starting the car, i have checked around and cant see anything obvious, had my fuel filter changed 3 weeks ago, so its not that.
    now i am getting pretty close to my r-tech trip next weekend, so has anyone had experience on this issue, and is it something i should get checked out before i go???
  2. Agric04
    Agric04 Member VCDS Map User
    288
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    A favourite of this problem is the little plastic pipe that goes to the evap next to the coolant bottle it splits on the ends. its a black corrugated plastic pipe
  4. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Dave what's evap? My car exhaust smells of fuel aswell when i start it, only started happning in the past few months though and i don't know what it is!
  5. Westy
    Westy Well-Known Member
    17,443
    1,104
    Running rich maybe ?!
  6. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    What's the reason for running rich though mate?
  7. Westy
    17,443
    1,104
    remap putting in too much fuel normally, Have you got a generic map?
  8. Greig300
    Greig300 Member
    257
    Try cleaning and checking your fuel cap... if its not sitting right it really can get strong. If it is the cap dont buy copies off ebay as they are junk and dont seal correct... i have one spare lying about :) it dont have the rubber wire that holds it to the car though.
  9. DavidW
    DavidW Member
    211
    My money is on the pipe Dave mentioned,it runs round the back of the coolant bottle and into the filter. It's only a push on plastic pipe, swap it for some rubber or silicone if it looks to be split.
  10. davidniclee
    davidniclee Member
    96
    i have the same on my a3 but ony just had it but carnt pin point it just smells quite strong
  11. s3dave
    10,110
    736
    Take the left hand cover off and all will be seen (by the coolant top up) it usually makes a ticking noise.....
