Fuel Regulator
Joshie Jan 7, 2003
  1. Joshie
    Joshie Member
    71
    Does anyone know anything about fuel regulators on the 2.7 TT engines?
    Apparently the factory fitted one is 4 bar and my mate, who lives in Denver, has been advised by OCT who have supplied him an upgraded ECU for his S4, that he should replace the 4 bar unit with an uprated 5 bar one.
    Is there any performance or reliability benefit in upgrading this /ubbthreads/images/graemlins/confused.gif. Perhaps JPR could advise.
  2. toasty
    toasty Member
    52
    When I had my Cavalier GSi2000 lots of people bought things called power-boost valves which I assume are just uprated fuel regulators
    If I understand correctly they just sit between the fuel flow and return line and maintain the fuel pressure on the injector bar(s) I think most of them work by using a spring loaded ball bearing.
    That's all I know sorry.
    RAM has a nice manual (60 pages) on the 2.7T engine which can be downloaded from his site, I would imagine that this has some info on the regulator.
    S4 engine manual
  3. Joshie
    Joshie Member
    71
    Thanks Dan - lets hope AmD can advise. I'm wondering if this was upgraded when I got the RS4 turbos fitted.
  4. toasty
    toasty Member
    52
    You certainly would have got a bigger fuel pump and injectors (both from the RS4 I think)
  5. danksy
    danksy Member
    75
    Simplistically the main things governing engine output are..
    i) Fuel in
    ii) Air intake
    iii) Exhaust gasses out
    Normally you'll reach the upper limits of the Air-flow in, or exhaust gasses out before you reach the limits of the fuel pump, and injectors!
    The old way of tuning diesels used to be to whack a bigger fuel pump in (from a van!!), that is before software came along!
  6. Joshie
    Joshie Member
    71
    This makes sense. The standard injectors remained - AmD said that the flow was regulated through the ECU which was remapped accordingly and RS4 injectors were not necessary with the KO4 turbos.
