  1. ttaalliibb
    ttaalliibb New Member
    24
    Hi
    I have a guestion about a fuel pump. Did some one know what is a maximum working pressure of standard pump? And what is a maximum BHP on standard pump?
  2. <tuffty/>
    20,847
    3,687
    Depends on which car... S3 has a higher rated pump (4bar) than the A3... in theory should support most hybrid turbos power up to around 350hp but only if the pump is in tip top condition... there have been a few failures recently as pumps are old and wearing out..
    If going for hybrid, factor in a new fuel pump... if going BT then factor in an inline pump too
  3. ttaalliibb
    24
    Haa ok thanks mate.
    I going to remap my car on the end of this month and i wasynt sure about pump but now I will hange it because i going for 350 .
    But have you got a some idea about fuel injectors? I fit a bosh 365 cc are you thing they will suport 350BHP?
  4. <tuffty/>
    20,847
    3,687
    Whats the spec of the mods? what car? normally fit Bosch 550cc injectors for hybrids etc when heading over 300hp... all on a 3bar fpr... no need for a 4bar one
  5. ttaalliibb
    24
    I have a few mode . Big turbo custom exhaust manifold lighened fly wheel with carbon cevlar clutch. S3gearebox, light pulleys 365cc injectors and i will fit a 5bar fuel pump .
    And the car is a a3 1.8t ajq engine fully refurbished engine.
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    what turbo? 5 bar seems excessive why not get bigger injectors?
    What lightened pulleys have you gone for?...:sly:
  7. <tuffty/>
    20,847
    3,687
    AJQ enjine is an A3 quattro isn't it?... if you know the intank pump is ok you could fit an external inline pump to support it like a DA-31... that will be more than enough
    As Dave said... what turbo?
  8. <tuffty/>
    20,847
    3,687
    s3dave likes this.
  9. ttaalliibb
    24
    I like them pulleys. They are more than1.5 lighte than oryginal. And for 60 £ is worth to buy it.
    I have a t3/t4 turbo with 27 psi boost.
    If I will have to then I will buy bigger injectors but not necceserly becouse I paid 50£ for them 365 cc injectors nad i dont want to spend too much money .
    And I need new pump because my pump has cover a 200000 miles.
  10. s3dave
    10,110
    736
    £60 is nothing compared to a rebuild/ new engine...please read the posts on tufftys link..
  11. ttaalliibb
    24
    Ok thanks for that ... i will ask seler that them pulleys are balanced just to confirm but then I will take them off.
    And back to the injectors . If i use a 4 bar with them injectors should run to 350 ? Of them injectors are not enought?
  12. Scullies
    Scullies Well-Known Member
    1,543
    657
    It's not about the pulleys being balanced, its about the pulley absorbing the high frequency engine vibrations.
    I also made the mistake up buying those pulleys, they make nice ornaments now :)
  13. ttaalliibb
    24
    Ok then I will take them off on weekend
  14. ttaalliibb
    24
    But what you thing if I get fuel pump with 5bar pressure them injectors will run a 350?
  15. rustynlc
    rustynlc Member
    186
    20
    Just to clarify for you folks it have a AJQ engine, 180bhp as standard and it's in a a3 Quattro,
  16. s3dave
    10,110
    736
    Have the rods been done?
    Injectors would only go up to 405ish? @4 bar so not enough at all, 550ccs are well on there way @350bhp
  17. ttaalliibb
    24
    No the rods not yet. That why I dont want to go more than 350. I need to consider what will be easier. New pump anf filter and all the pipes or just buy and re fit bigger injectors.
    Then if i fit 550 injectors then i will be able to run them on standaerld pump?
  18. ttaalliibb
    24
  19. ttaalliibb
    24
    And there is a wsy how tu check injectors pover?
  20. s3dave
    10,110
    736
    550s and a new pump would be best mate, be careful @350 on standard rods...:ermm:
  21. ttaalliibb
    24
    That is a safe power. Crank is forget then...
    And there is a few them audis with 350 bhp in poland and they have no problems. And i am a careful driver and I will not overuse that power
  22. s3dave
    10,110
    736
    Crank is fine for a lot more than 350bhp its the rods that will be unsafe, anyway your car mate... just warning you
  23. ttaalliibb
    24
    Ok .
    I will change them later on because now I sepnd all my sawings. But what about pistons? If i fit forged rods do I need also a forged pistons?
  24. s3dave
    10,110
    736
    Pistons are fine @ 350..;)
  25. Scullies
    1,543
    657
  26. ttaalliibb
    24
    Aha I will see how is going on dyno and then I will see it meybe i will go for less. But how you thing what power will be safe for my?
  27. s3dave
    10,110
    736
    Its the Torque that kills the rods, nobody can tell you a safe level mate, its a lottery, obviously the linear the map the better
  28. ttaalliibb
    24
    Thanks mate
  29. ttaalliibb
    24
    Aha
    Thanks for all mate
  30. Sam_
    Sam_ Down under
    3,034
    478
    An image commonly used by Bill...
