Fuel pump replacement
sakkie69 Jul 15, 2008
  1. sakkie69
    sakkie69 2008 Audi S3
    199
    Is there somewhere a bulletin or link to the different fuelpumps on the S3s? I have the "old" fuelpump on my car (apparantly) and want to take the car to Audi to replace it, can I just ask that they put the new revision in due to upgraded one being out, is there a recall out or does it actually have to fail first? Any one got the fuelpump numbers as well (which models are old, new etc)
  2. julians
    julians Member
    312
    I didnt know there was an 'old' and 'new' fuel pump. But.....
    If you pay them, they'll do whatever you ask.
    If you want them to replace it for free, it'll will either need to have failed and be covered by warranty, and theres no guarantee they wont just replace it with another 'old' one. Or there will need to be some sort of recall out for it (which there isnt).
    Why do you want it replacing?
  3. sakkie69
    199
    The new fuel pump is supposedly an H model, was fitted from middle of 2007 onwards or so according to dealer. The earlier fuelpumps have delivery issues in midrange, hence why so many chipped people have the Autotech pump. The new pump from VW/Audi addresses the issue and also stops some failure that occured in some cars.
  4. Rabbit222
    Rabbit222 Active Member
    708
    125
    43
    I took the liberty of having my internals upgraded in my fuel pump to the Autotech internals. In order for Audi to actually upgrade your pump from H to the newer J revision, your car will need to throw a consistent low fuel pressure code on VAS. Has your car been remapped yet?
  5. sakkie69
    199
    I got told to check my fuel pump first because they were having issues with some cars with the older pump.
    Who did the upgrade for you on the pump?
  6. Rabbit222
    708
    125
    43
    What software are you planning on remapping your car with? If its GIAC then I'm betting you are going to have an issue. I purchased the bits from FRC and they arranged for my local Audi dealership to have it installed.
  7. gtijames
    gtijames Member
    46
    Interesting. So does having the new H revision pump give you the same as having the Autotech internals?
  8. maxS3uk
    maxS3uk mike
    110
    I'd be interested in knowing this too, as I was going to upgrade the pump but if there is no need I wont!
    Is there a part number on the pump somewhere?
  9. Rabbit222
    708
    125
    43
    You mean J. Not too sure mate but I do know the H pump has been superceded to the J pump. A mate of mine had the low pressure fuel code and had his replaced with the J pump...he also did the Autotech internal upgrade to the J pump.
  10. jamiekip
    jamiekip Guest
    Interesting thread!
    Will be speaking to my dealer about this...
  11. Rabbit222
    708
    125
    43
    Abit difficult to get to the part number mate, best check your VIN number and call your dealers parts dept, they should be able to give you the part number if you provide them with your VIN.The last letter on your pump part number should be either a H or J...obviously depending on which one your car has.
  12. sakkie69
    199
    Is there an easy/quick way to check what revision you got by the way? Just to confirm if the dealership did swop it out I can verify it myself without having to run to the tuner first.
  13. Rabbit222
    708
    125
    43
    Easiest is to do what I posted earlier. Call your dealer Parts dept and give them your VIN number. With that they should be able to tell you what parts are in your car.
  14. wolfbane1967
    wolfbane1967 Member
    237
    9
    This is how the old pump looks like,its just under the engine cover when you remove it
