Fuel Pump Relay - Where is it?
E36graduate Oct 11, 2009
  1. E36graduate
    E36graduate New Member
    22
    where would i start looking? owners manual?
  2. golf
    golf ***** rent boy VCDS Map User
    1,556
    Remove the panel (storage compartment) underneath the steering wheel and you will see four relays, the fuel pump relay is the one on the left. It's a 9-pin relay labelled "167".
  3. E36graduate
    22
    Thanks mate. It ended up being a cracked fuel line inside the fuel tank. I measured the volts at the pump and was getting the 10 volts when cranking. I thought my fuel pump was toast...however a relief when I saw the gas pouring out of the pump through the cracked line inside the tank.
