Fuel Pump Prime
LCR225 Jun 23, 2014
  1. LCR225
    LCR225 New Member
    13
    Hello,
    Can someone with a 2.0 TDi 170 confirm whether they hear the pump prime when opening the drivers door? Or should it only do it when ignition is on?
  2. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,075
    715
    I have never heard my pump when opening the door. I struggle to hear it in the car when I switch it on.
  3. j4yvw
    j4yvw Member
    50
    hi mine is the same it only primes when you switch it on. The issue i have is if i don't use the car for a few days it will not start straight away, it takes a coulple of cranks to fire up.
    So what i do now is to prime it a few times and it fires on the first crank.
  4. LCR225
    LCR225 New Member
    13
    Thats the very same issue I have. Trying to get to the bottom of it as it's getting worse to start from the first cold start of the day. As in takes around 8 goes before it starts.
    Noticed its more when the car has half a tank or less of derv left.
  5. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    I have the same problem: http://www.audi-sport.net/vb/a3-s3-...hen-fuel-less-than-half-tank.html#post2172753
    I've recently got a used in-tank pump from a friend, for testing and the starting problem has gone.
    I'm going to buy a new pump.
    The problem is that there is a one-way valve on the circuit that should prevent the fuel to drain back in the tank. This valve is failing and can't keep the system pressurised.
    A lot of details here: 2005 BEW PD lift pump operation and internals - TDIClub Forums
