Fuel pressure - S3
jesters3 Nov 21, 2007
  1. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Arvo, a couple of times when I have gone to fill up, there seems to be a lot of pressure coming out of the fuel tank. As a result I have to keep the cap on and unscrew it slowly to let the air out; if I take it off straight away petrol spews out. This lasts for a good 30 seconds.
    I smell petrol every now and again from the front. I'm thinking I may have to get the fuel filter changed as the build up may be from here.
    Any ideas?
  2. campbell
    campbell Member
    721
    change the fuel filter and see if its any better, simple job if up on ramps
  3. jojo
    28,846
    3,509
    Mine makes a little chirp which lasts under a second, and no fuel spirts out, get it checked mate.
  4. jesters3
    1,516
    Yeah not brilliant, going to get the filter replaced as it has done 149k worth of fuel! Hopefully that should fix it.
  5. patrick swayze
    patrick swayze Member
    81
    do it yourself, it takes like 5 minutes?
  6. jesters3
    1,516
    Will do, Getting the filter tomorrow from VAGPARTS and doing it at the weekend, seems straightforward enough, just have to remember to depressurize the system before I crack on!
  7. mazzy
    mazzy Member
    303
    So does changing the fuel filter resolve this issue??
  8. jonS3
    jonS3 Member
    719
    even if it doesn't it's worth changing anyway for the sake of a few £ and the fact that about a million litres of fuel have passed through it.........
  9. mort
    mort New Member
    judging from there being no more posts i take it replacing the fuel filter solved the problem? I know it was about 2 years ago but im just asking because i have the same problem!
  10. jesters3
    1,516
    No i'm afraid not.
    The issue came down to a fubar gravity valve (part 14)
    This meant dropping the fuel tank to get to the part and then to replace. The part is about £5 but takes 3-4 hours to sort out.
    I had to get it done at a Stealers and it cost me £500ish all in. If you get this done at an indie it should be half the price.
