Fuel leak - help!
z00bz Sep 22, 2013
  1. z00bz
    z00bz Member
    50
    I started gettin fuel smell inside the cabin, opened the bonnet and spotted fuel leak from the area shown in the pic.
    The cars running as sweet as always and can't seem to tell a difference in the fuel usage and no warning signs either. It's doesn't seem to happen all the time but the leak is often.
    Took it to a garage yesterday and funny enough as it happens, there was no leak so couldn't do anything at the time!
    Any ideas?
  2. z00bz
    z00bz Member
    50
    Any confusions on the pic, this is the area next to the coolant bottle, under engine cover.
  3. Scullies
    Scullies Well-Known Member
    1,543
    657
    best to get a picture with the cover off
  4. z00bz
    z00bz Member
    50
    Will post a better pic 2moro, cheers
  5. z00bz
    z00bz Member
    50
    Right peeps, iv managed to take a pic with the engine cover off. The area where the fuel leak is where the fingers pointing near the 'bottom' silver jubilee clip with the screw. As mentioned it doesn't effect the drive nor has any warning signs on the dash!
    Any thoughts?
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yes that is your fuel rail feed or return , so i would get it sorted asap !
  7. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Check the clamps/clips are tight where they attach to the rail/hard lines. What year is your car? 02 or 03?
  8. z00bz
    z00bz Member
    50
    So is it the hose that's probably perished and needs replacing?
  9. z00bz
    z00bz Member
    50
    The clamp/clip I untightened and moved it closer as seen in the pic and then tightened again but seems to not have made a difference.
    Mine is a 1999 T plate
  10. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    I think you should get that sorted as a matter urgency or go get a fire extinguisher fitted ASAP :)
    try not to use jubilee clips like that, they don't apply pressure in a perfect circle. OEM clips all the way or get a decent pipe clip which tensions evenly.
  11. z00bz
    z00bz Member
    50
    Yes unfortunately this is how I bort the car, just ordered the part today from TPS with clips, unfortunately there is back log with parts so iv been advised 10 days...!! So iv left it parked up and using the Mrs's motor.
    Will get it sorted asap! I'm surprised I'm still alive :-/
    s3dave likes this.
  12. z00bz
    z00bz Member
    50
    New fuel feed and return pipe and 'proper' clips from dealers. Can't believe I paid £91 for a set of 2 rubber pipes!! Aarghh!
    jojo likes this.
  13. z00bz
    z00bz Member
    50
    Problem seems to be sorted now :yes:
  14. jojo
    28,859
    3,518
    The cost of doing it right! Glad it's fixed!
    Buneet, JudderMan and z00bz like this.
  15. JudderMan
    JudderMan Well-Known Member
    1,004
    164
    True dat! It's not cool having fuel spat at you or ignited fuel isn't any funnier. Electric shocks are in this same category*.
    *The joys of being a classic mini, beetle and mk2 escort owner of the past....
