Fuel guage problem
AndyCollins May 14, 2004
  1. AndyCollins
    AndyCollins Member
    181
    Hi Guys
    have just purchased a 1999 A4. I have noticed that when I fill the car with fuel the needle on the guage doesn't go all the way to the top. It sits half way between 3/4 and full. Is this common or is something wrong?
    Many thanks
    Andy
  2. neiloneilo
    neiloneilo Member
    183
    I bought a 1999 S3 2 weeks ago, and ran out of fuel at 1/8 full with the computer saying 30miles to go.
    I bumped into the dealer manager in a pub who informed me that it just needs recalibrating.
  3. I thikn this is common on Audis. My S4 is exactly the same. when the computer says 10 miles left, it only takes 40 litres of fuel of out a supposed 62 litre tank!
  4. leespears1
    leespears1 Member
    261
    common with quattro as fuel tank is wierd shape due to the diff i think.
  5. godwine
    godwine Member
    40
    leespears1 is right. That is something unique to the Quattro only due to the shape of the tank.
  6. Mutinyno9
    Mutinyno9 Member
    248
    I had the same problem on my 99 A4. I took it to a dealer and got it fixed for $400. For an alternative, there is tech article on www.audiworld.com that walks you through steps on fixing it yourself.(i wish i would have seen that before it took it to a dealer, but oh well its fixed now)
  7. ImolaS4
    ImolaS4 Member
    275
    NO, NO, NO!!
    This is a classic sending unit failure. If the car is under warranty, it will be replaced at no charge. It takes about 1 hr. labor, of which, some of that time is taken up by driving the car with the windows down after the R&R because fuel fumes get into the cabin. The unit is accessed through the interior of the car - the trunk.
  8. Mutinyno9
    Mutinyno9 Member
    248
    I had to go with dealr(or independant) i didn't have warrenty
  9. JAmenda
    JAmenda New Member
    13
    May car is in the shop for this right now! Something to do with the dash I was told! I will update once I get it back!
  10. Mutinyno9
    Mutinyno9 Member
    248
    Thats what they told me too
    "we had to first see if the problems was with your cluster guages' dial"
    Then later they told me it was my fuel sensor
  11. JAmenda
    JAmenda New Member
    13
    What was the final resolution for this? This way I can give the mechanic a hint since it seems like he has no clue at this point! Thanks!
  12. Mutinyno9
    Mutinyno9 Member
    248
    Well, for me, it was the fuel sensor
  13. JAmenda
    JAmenda New Member
    13
    OK thanks, I guess we have two different cases here. I will let you know the outcome of my situation.
  14. Mutinyno9
    Mutinyno9 Member
    248
    If its the sensor, i would say do it yourself, if you have the resources(time, and alternate transportation(if needed)) If its is a problem in the Guage i would say let the mech. do it. But yeah keep us posted on the final outcome.
  15. neiloneilo
    neiloneilo Member
    183
    I've just dropped mine off this morning to have a few things sorted under warranty including the fuel problem. When talking to the mechanic about the fuel he said it will be a cluster gauges change. Only I don't intend on testing if they fixed the problem, I ran out of fuel with 1/8th remaining.
  16. AndyCollins
    AndyCollins Member
    181
    Original poster: My car is a 99.5 A4 and is out of warranty. Could someone recommend what my next course of action should be? How should I determine if it is the sender or the cluster guages? If it is the later how much would this cost in the UK?
