Fuel Gauge Dead
AndyS3 Apr 19, 2005
  1. AndyS3
    AndyS3 Member
    133
    One month out of warrenty and the fuel gauge has decided to die, needle is on zero, DIS is displaying Zero and fuel indicator is on.
    Anyone with any experiance with this fault, is it the sender unit or the cluster. I'm thinking the sender unit seeing as i have all 3 indications and what cost will this be to repair?
  2. AndyS3
    AndyS3 Member
    133
    No one /ubbthreads/images/graemlins/frown.gif
    Where is the location of the Fuel sender?
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    do you have vagcom or access? You can check how many litres are left in your tank using it on the cluster info module.This could ascertain if it is the sender or the display. The sender is in the tank IIRC
  4. jcs356
    jcs356 Brum brum
    2,727
    67
    Mine did this once - but it sorted itself out the next time I filled the tank.
  5. benk
    benk Member
    469
    Same here - mine went weird when I let tank get low (I normally refuel at 1/4) and needle went full-empty-full-1/2-full-empty.
    After refueling it that time it hasn't done it since, but I also haven't let it get that low.
    I put it down to the sender getting **** on it or something, but who knows.
  6. AndyS3
    AndyS3 Member
    133
    No i dont have VAG-COM.
    Its started working again today. I'll wait and see what happens when i fill up next time.
  7. JamS3
    JamS3 Active Member
    2,258
    23
    Mine is doing exactly the same!
    One minute its ok the next its dropping right down like a stone!
  8. ELIASGK74
    ELIASGK74 Member
    47
    today mine was moving left and right!
  9. jpda4
    jpda4 Member
    127
    21
    mine reads empty for 10 min ish after been stood overnight
    then slowly creeps up towards some kind of reading
    it has also gone 1/4 tank out on the reading after a minute
    or so of rapid movement/ flickering pointer must have turned
    a bit on its
    warning light now goes out just past the 1/4 tank mark
    im living with it
    us the trip meter to decide when to fill normally 330 mile
