Fuel filter changing
A3-frankie Oct 7, 2006
  1. A3-frankie
    A3-frankie Member
    118
    Morning guys,
    I'm servicing my A3 130 tdi.
    Only thing im unsure of is the fuel filter, where it is ( ive not looked yet ) And when i change it will i have problems with air in the fuel system as it is a diesel and end up having to bleed the system.
  2. 28v6
    28v6 Guest
    It should be located to the right hand side of the engine near the block, failing that it maybe out on a wing (Like me)...but once installe its just a matter of running the engine at idle until it smoothes out.. Its a self bleeding system so you should okay...
  3. J4CK-DE
    J4CK-DE New Member
    should be two pipes goin to it and a block with two more pipeswith a R clip on top be carfull that plastic is weak some u have to twist and pull others just pull out
    when u have to the new filter in place just fill it up with new diesel and then install the plastic block and R clip and two pipes
    then you wont have no problems
  4. A3-frankie
    A3-frankie Member
    118
    Cheers guys,
    All serviced now. I didnt fill it up with new diesel, i went ahead and did it before i read your last post. had no problem though, idled lumpy for a second while the filter must have been filling up and job done.
