Fuel fault tdi????
WOLF Jun 5, 2014
  1. WOLF
    WOLF Well-Known Member
    1,201
    270
    My fuel light and beeper came on so i pulled into garage and put £40,upon getting back in the car and turning ignition on the fuel light and beeper were still on and the gauge hasn't gone up.................any ideas guys??
  2. Greg190t
    Greg190t Guest
    Level sensor in the tank has failed?
  3. WOLF
    1,201
    270
    Well i thought about the float level in the tank to start with but dont know,sounds feasable i guess...........
  4. Greg190t
    Greg190t Guest
    Not a lot else controls it mate, unless you dials have given up
  5. WOLF
    1,201
    270
    All other dials work fine,temp guage,centre display etc so yeh maybe your right.
  6. WOLF
    1,201
    270
    Any idea wheres the best place to get one?
  7. Greg190t
    Greg190t Guest
    I'd ring GSF for one
  8. WOLF
    1,201
    270
    Or eurocarparts,cheers mate......appreciate the imput:beerchug::icon_thumright:
  9. Greg190t
    Greg190t Guest
    Euro's will be **** poor quality
  10. WOLF
    1,201
    270
    gsf then:lmfao:
  11. sumo
    sumo Active Member
    220
    47
    Before you buy a new sender give the bottom of your tank a thump to see if its just stuck.
  12. BakPak
    BakPak No Gear
    957
    137
    43
    Ran my tank very low once and the sender stuck in that low position. Took a few miles driving before it freed itself. So yeah give the tank a few thumps!
  13. WOLF
    1,201
    270
    Ive thumped the tank and put more fuel in but no joy,dealer part only at £90 so ill try a used one if ican find one!
  14. WOLF
    1,201
    270
    Can anyone recomend a decent audi breakers or another outlet to buy one from?
  15. WOLF
    1,201
    270
    So i got myself a new level sender,ive removed the rear seat to find 2 plates with 3 screws.passenger side has exhaust heat shield and drivers side has top of tank,theres no sender in sight so were the hell is it????
    Help guys im stumped
  16. sumo
    sumo Active Member
    220
    47
    Passenger side is for a quattro ie saddle tank has twin sensors.yours will be on the drivers side and the sender will be attached to the fuel pump inside the tank.
  17. WOLF
    1,201
    270
    I expected to see it under the inspection plate but all there is is the top of the tank.....no sender or pump.....confused
  18. sumo
    sumo Active Member
    220
    47
    Sorry my bad its in the boot under the carpet, inspection plate with 3 crosshead screw's.
  19. WOLF
    1,201
    270
    Yeh already found it mate but how do i get the full pump out of the tank,doesnt seem to fit through the hole
  20. WOLF
    1,201
    270
    pm sent:icon_thumright:
  21. sumo
    sumo Active Member
    220
    47
    Hi mate, it will fit with the sender fitted its just a bit tight. Is there a long pick up pipe fitted? If so pinch the clips on top of the pump and lift it out of the tank.
  22. WOLF
    1,201
    270
    Pickup pipe.......there a few pipes lol.
    It seems to have a metal bracket type cage on it so its really a bulky thing to extract.
    Do i need to remove the top part(the bit where the electric plug and full lines clip on to)its pushes up and down?
  23. sumo
    sumo Active Member
    220
    47
    No don't take it apart ie top and bottom parts.
    WOLF likes this.
  24. WOLF
    1,201
    270
    Ok,
    im going to try again tomorrow,im going to turn it and hopefully it will come out.
    appreciate the imput sumo:icon_thumright:
  25. sumo
    sumo Active Member
    220
    47
    No problem, will come straight out tomorrow!
  26. WOLF
    1,201
    270
    fingers crossed mate:salute:
  27. WOLF
    1,201
    270
    Eventually got it out and fitted new sender................Arghhhhh its not worked and still got the fuel beeper and no fuel guage!
    £73 and still the same problem is annoying.
  28. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    any fault codes showing ?
  29. WOLF
    1,201
    270
    Im just trying to get a diagnostic done so anyone localish to doncaster fancy plugging me in?????
  30. WOLF
    1,201
    270
    Uhhh,so now my guage is working (slow to rise but eventually) but the beeper and fuel light telling me to refuel....WTF:wtf:
  31. BakPak
    BakPak No Gear
    957
    137
    43
    Could be a gauge or DIS issue dude. All that beeping would destroy me...
  32. WOLF
    1,201
    270
    The beeping is very annoying,next job is change the cluster..........
  33. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,762
    167
    Next job would be to do a full VCDS scan and an output test on the cluster to test the dials etc before just buying parts that 'might' be faulty.....
  34. WOLF
    1,201
    270
    Yeh vcds first before buying a cluster is what i meant;)
    S4_dan likes this.
  35. Bennettrfc
    Bennettrfc New Member
    15
    Tell me u checked fuses before spending that money?
  36. WOLF
    1,201
    270
    Yes i checked the fuses:icon_thumright:
  37. WOLF
    1,201
    270
    And as if by magic...................everything working fine:think:
    Strange one.
  38. Josh84
    Josh84 Member
    74
    I have the same problem with my a6. It happens maybe once every 3 or 4 months, but the dial eventually goes up on the same day. Was at a garage 1 time when it happened they couldnt see any faults or find why it was doing it.
  39. WOLF
    1,201
    270
    It appears the guage fault isnt cured but comes on/off intermittently.................borrowed a mates plug in reader,engine/srs,a/t and abs checked but came back with no fault codes..........i would have thought some error coe would have been found.............??
  40. WOLF
    1,201
    270
    Im amazed you knowledgeable lot cant help here:racer:
