A4 TDI 130. engine code awx.
seems heavy on fuel locally and brilliant on the run.
87.9 pence per litre = 100 miles and it used 15 pounds. local.
on a run it did 105 miles on 8 pounds(seems ok)
How can i check via vag-com if its running rich or if fuel deliver is as it should be,please direct me on how to do a measuring block test.
sebastian has give the fuel injectors all clear there readings were : -0.75 -0.42 0.66 and 0.52 mg/str
it is taking 3-4 seconds to start,on some weeks it starts instantly ,fully seviced new temp sensor,and all filters, checked in engine bay no visible leaks or split hoses, had enough
