heres my findings thus far ,
had a problem with the plugs in that the motor factors sent the original NGK PFR6Q instead of the requested NGK IRIDIUM BKR6EIX so was foarced to fit the standard item , took old ones out ( same standard) and measured the gap which was between 9-10mm they were also a healthy light tan colour and didnt look too old, gapped the new plugs to Wellys spec 7mm, changed the fuel and air filters, cleaned the MAF with electrical spray cleaner, cleaned the PCV and TB with carb cleaner, checked all hoses were secure and no leaks , logged any faults b4 work and showed Clutch peddle sensor prob so took it out and cleaned it and reinstalled it
went short test drive then looked for any fault codes all was clear , went longer test drive and ragged it
I couldnt beleive the difference in performance it feels like a new car much smoother and quicker reving, very noticable improvement, so went back to garage looked for faults none to report other than my boost pressure is an expected 950 mbr but im getting reading of 990 ???
what does this mean ? has my car been remapped as everything else appears ok and no faults , its 2 weeks since i changed the thermostat and coolant and the temp gauge sits bang on 90 deg all the time except when sitting ticking over it will rise to approx 95 on the gauge then the fan cuts in and quickly goes back to 90
im now sat at just under half tank and gonna run it untill the fuel light comes on again and give the BG 44K time to do its job as they reccomend to use the tank over a 2 week period and should be filled at quarter tank again...
so still keeping a close eye on the fuel consumption and several sheckles later hopefully i will get better milage will keep everyone posted
