fuel additives
cubby May 1, 2009
  1. cubby
    cubby Member
    64
    hi. Does anybody use fuel additives on here? I've an a3 2.0 tdi sport. Was thinking along the lines of redex or something. Do they work? Thanks.
  2. gixxer600k4
    gixxer600k4 Member
    692
    i try and use some on every full tank, i use super unleaded and some redex, it is good, it clean out the injectors, valves and sparkies, may be worth looking at some oil additive too, this will clean inside the cylinders and increase the lubrication
  3. frenchy2475
    frenchy2475 Tetbury Audi Parts Man
    263
    Alot of people swear by the Millers Diesel Power Sport 4 additive, increases the cetaine rating too for extra performance.
  4. cameron1
    cameron1 Member
    56
    Any of you heard about Borpower (nanoboron) oil additive?
    It apparently decreases engine wear and increases mpg, I haven't had the balls to try it myself yet, although there are some independent tests on the web which looked promising.
    Nearly all the oil additives in the past were proved to be just snake oil, although the jury is still out on this one I think.
  5. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    IL BE BUYING PLENTI THEN ..... EFFIN HATE SNAKES LOL
  6. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    i use redex with vpower diesel
    not sure about the vpower but redex made the engine feel smoother and looser..
  7. piers90
    piers90 Member
    99
    i use shell V+ or BP Ultimate all the time and occasionaly used the redex fuel additive and am sure it makes the diesel sound less 'clunky' lol.. and the V+ fuel does seem to make it run smoother...was looking for the test 5th gear did on V+/Ultimate fuel on youtube, but cudnt find it.. anyway, they did alot of tests with machines and sensors etc and with one use it increased BHP by like 1 or 2% or summit and with regular use will add more BHP..
    while lookin for this vid tho, i found this test they did
    http://www.youtube.com/watch?v=Vj_21dikYR8
    is on fuel addatives and gives the best answer your looking for i think..
    Piers:thumbsup:
  8. MikeSel^
    MikeSel^ Systems Support Specialist
    558
    I use redex infact, I have just been and put some in now :)
  9. Flibble
    Flibble Active Member Team Estoril
    543
    141
    43
    Don't use any, just use vpower.
  10. FL1X
    FL1X Member
    61
    i used to use Redex on my petrol Focus since i got the Audi i havnt Used anything.... Yet
